Does the 4.0L twin turbo V8 have turbo lag?
I have a amg GTS and I notice when I put my foot down I get a solid 1 second delay before the car starts to pull hard. It’s especially evident from a standstill so I’m trying to understand why that is. I imagine it’s lag from the turbos trying to build boost? The only way I can avoid the delay is easing into the acceleration but that takes away the wonderful “oh ****” feeling when you plant your foot. Perhaps it’s the ECU cutting traction? Limiting the traction (sport) mode helps a bit but there’s still a delay.
Jerry
Received 3,938 Likes
2019 C63CS
Well, pretty much all turbocharged engines have some turbo lag, unless they have an electric turbo or a hybrid system that can do torque fill. Having said that, though, the AMG V8 feels as close to a naturally aspirated engine that you can get with a turbocharged engine. It's a very responsive engine and turbo lag is virtually non-existent. What mode are you in? The throttle map in Comfort is deliberately feathered, but in S+ and Race this engine just responds and goes, and Race mode has a very linear throttle response that if I didn't know it had turbochargers I could swear it was a naturally aspirated engine. AMGs stated goal with this engine was to make it feel and respond like a naturally aspirated engine. Traction control/ESP can and does limit the engine torque w/o necessarily any indication in the instrument cluster. With my 2019 C63S coupe in Comfort mode it definitely limits torque if I step on the throttle while turning. It does this proactively to avoid a spinout, but with ESP in Sport and AMG DYNAMICS in Pro or Master it doesn't do that and just goes and slides around the turn. Your GTS doesn't have the new AMG DYNAMICS system, nor the 9 stage traction control system that the GT R and above have as well as the 2019+ C63S, so the only way you can make ESP less intrusive is by putting it in Sport Handling mode or turn it off completely.
The following 4 users liked this post by superswiss:
The following 2 users liked this post by boosted20v:
daybx (06-27-2022),
TriggrPullrUSMC (06-23-2022)
2019 C63CS
Yup I try it in all settings and in comfort mode there’s definitely a delay and in sport, sport + it’s less and less. In race mode it feels non existent but I tend not to use race mode on the street as you run out of run very quickly. For example when I’m on the highway and I put my foot down there’s a slight delay like the car thinks for a second and then goes…but, it almost feels normal for what I’m asking the car to do. I was just curious if there was a slight lag when accelerating or if it was normal
This issue doesn't exist with the MCT transmission in other AMGs like my C63S. The MCT, because it uses a planetary gearbox and multiple clutches, it can skip gears in an instant. A downshift from 9th gear to 4th for example on the highway with kickdown happens in an instant. There's pretty much zero delay and zero interruption in tractive force. This particular situation is really the Achilles heel of a DCT. DCTs are great on the track when shifting sequentially, or if you are primarily shifting manually and select the proper gear in advance before stepping on the throttle, but they fall flat on their face if they end up having to shift out of sequence.
I'm with the others, this car really has no lag to me. But I have nearly lost my car due to the delay type thing you are talking about but that to me was just where I was in the wrong gear and the car is too powerful. I'm more careful now if I'm slogging around in C and decide to take off, instead of waiting on the car, I'll manually downshift a gear or two.
The other funny thing to me is the bump you get as the transmission downshifts coming to stops. I have another car that does that, but no where near as noticeably. Actually I enjoy it, but it is pretty wild.
2019 C63CS
Yeah, I can really only encourage folks to drive more in manual mode. Personally, I drive in manual mode at least 90% of the time. I have my Individual mode configured to put the transmission in M. Particularly on the highway, unless I'm just cruising along with DISTRONIC, I'm permanently in manual mode and control the gears myself. After 20+ years of driving manual transmissions, making sure I'm always in the right gear is second nature. As good as the automatic modes are, they still can't read your mind. These cars are simply more fun in manual mode, and if you know what you are doing, you get the response you want.
Damnbear (06-14-2022)
2019 C63CS
- If you press and hold the downshift paddle for a second or so it drops to the lowest possible gear. Basically a manual kickdown.
- You can press the downshift paddle multiple times in quick succession to drop multiple gears in one shot. For example pull it twice quickly and it downshifts 2 gears in one blip.
sevenhead (06-24-2022)
A couple of tricks that come in handy:
2019 C63CS
I've never felt anything like this in my car, it was always near instant power/acceleration.
Bentley Continental GT; AMG GT
Nope, never felt anything like that. It's a drive-by-wire system and the throttle pedal always feels the same. It just has a different map based on the Drive mode you are in. In Comfort the map is progressive, in S and S+ it's aggressive and in Race it's linear. So a given amount of pedal travel results in a different response depending on the mode, but it doesn't change any weighting in the physical pedal travel.
Agree with Superswiss including the drive selections. I think I've only had my car in comfort mode twice since I've owned it and I am always in manual mode, but for other reasons too. I don't like the factory throttle maps as they are all geared towards fuel economy, even in the sports modes. For example, if I let the car shift itself and I am leaving a typical traffic light, I'll be in 5th gear in several hundred feet. This type of throttle map contributes to carbon buildups on the backs of the intake valves on direct inject engines. I always wind out shifts to at least 3K or 4K RPMs.
On the "Drive by Wire" and throttle maps, this is a complex subject and can be difficult to understand. MFGRS use different throttle maps to complement different selectable "mode" settings as illustrated in SS' diagram above. I can illustrate it a little further using a scan I did on a recent tune doing a third gear pull.
On the left, you can see 4 different rows of "throttle" (3 throttle and 1 accelerator)
COMMANDED throttle - comes from the driver. In this case I was commanding 100% throttle.
RELATIVE throttle - is what I got 71%, at the moment of the white vertical line when I commanded 100%, and what the fueling and timing was responding to
THROTTLE POSITION or better known as "actual" or "physical" throttle position (based on what the TPS sees) 83.9%
The ECU was using a Position D map
As I select different driving modes, and based on what (how) I COMMAND throttle, the combinations/patterns of these 4 throttle positions change based on the architecture built into the EMS.
I'm guessing here, but I think what Poutab1 was referring to about a "heavier" throttle feel when he stated
Silly question, do you notice the throttle is ‘heavier’ in manual mode? When I played with it before I almost felt like I need to push the accelerator slightly down more to start moving the car
sounds more like the DCT clutches engaging to get the car rolling from a standstill. Sometimes that can feel like more pedal is being pushed to actually get the car rolling and is really happening.
If I have the GTC in comfort mode there is a small amount of lag but it is probably a combination of computer telling car to be in highest gear possible (and then having to downshift when I give gas) and turbo lag because engine is in really high gear and turning very low rpm.
Now if I put car in any other mode especially s+ or race mode then there is no turbo lag because computer keeps trans is gears that leave the engine turning high rpms.
Surge (06-21-2022)
Very interesting. Thanks for sharing the details here. Looks like the biggest takeaway for me is to get the most fun and responsiveness out of the car, keep it in manual mode!
WRT throttle mapping/response, there are 2 things to consider:
- the mapping for the pedal position
- the mapping the ECU does in response to your "pedal-based request" ... which can be _very_ different from what you've requested via the pedal as the ECU takes into account such things as traction-control and (if you have it) the dynamics mode
Many of these videos show the throttle pedal position as well as the ECU throttle information for both a GTR (which has dynamics) and an older C63 (without dynamics). It's quite instructive if you want to see how these work under various conditions:
https://www.youtube.com/playlist?lis...XDlOogyMcpvvbW
W463 G550 / C190 GTC //prev: W204 C63 507 / R170
There is no discernible lag. You do need to ensure the transmission is in the right gear though. If you're in 4th in Comfort doing ~20mph, then yeah, it will take a second or so to downshift.
