From an AMG GT (Base) to a GT-R. What's difference from a 2019 to 2020?
Thank you!
if you do a search on the keywork "facelift" you will be able to find a lot of info on this form.
2019 will be significantly louder, as the 2020 model (i believe) had to be fitted with an additional particulate filter (OPF) exhaust side.
I also test drove 2018 and 2019 models back to back and actually found the 2019 to be a tad bit louder than 2018.
2019 will have the classic, no-nonsense mechanical buttons and knobs respecting the original "V-8" design concept of center console and Analog gauges with CF background, in addition to a Wheel +Touch-pad infotainment navigation.
The 2020 will have rectangular TFT buttons on center console, full Digital screen for gauges (much higher replacement cost if fails), with option for Touch-pad vs. Wheel (but not both)
2020 has the 'updated' Headlights, but in my opinion, this 2020 daytime lamp design ("squinty" appearance) is more tame and less sinister looking than the original Headlights with more aggressive appearance of the daytime lighting angle.
2020 has the side cannards/lip extensions for front bumper, which can easily be retro-fitted on 2019 and earlier MYs (https://mbworld.org/forums/coupe-roa...20-2018-a.html).
Other differences that 2020 has, over the 2019:
P44 –Parking Package –Now includes a Front Camera
U88 –AMG Drive Unit Steering Wheel Controls
NTG 5.5 including Apple CarPlay, Android Auto, and AMG Track Pace
New 12.3” fully digital instrument cluster
New 10.25” multimedia center display
In my mind, to maximize Warranty, etc and still preserve the loud exhaust notes and classic/analog gauges, I chose to go with the 2019.
And for a $30K pricing difference, the 2019 appears to be a no-brainer if mileage and condition, etc are similar.
All things otherwise equal, I'd go for the 2019. I now wish I'd bought a 2019 roadster, but none were available in mid 2020.
If u ever decide to do downpipes then u dont need to worry about particulate filter on 2020 and up
- front camera
- integrated apple carplay (wired)
- updated infotainment (and larger display screen)
- digital dash
- digital buttons in center console
- updated front headlights
- updated steering wheel & controls
- touchpad control (optional)
- steering quick control buttons (for exhaust, drive mode etc)
The delta in cost between 2019 and 2020 has remained pretty significant. Underneath these updates the car remains the same from a drivetrain/performance standpoint. The added cost is from these items, typically lower mileage, and of course, added warranty coverage due to the year of the car.
- front camera
- digital dash
I pretty much agree with you on your reasoning and choices although my bolded list would be longer than yours on an item maybe two.
Best,
Acta
I do miss a front camera a bit that the 2020’s include.
That said, I can have the front camera retrofitted like factory by a local audio professional.
Has anyone added the OE or any other brand camera to the front bumper?
https://mbworld.org/forums/c63-c63s-...ml#post8019562
There's also a picture of the camera view in that thread. They may also have one that works in your vehicle.
Also from me, a great thanksgiving to all.
Is this the biggest national holiday in America? (After the Superbowl)
There is thanksgiving in Germany, but it was rarely celebrated.
The NAV model described above uses the AUX input of the command. Not badly done. Might work on GT too (try W205 setting)
In the GT models without a front camera, the reversing camera is connected directly to the command. (+ Ground, +12V , +HMI CAN Bus)
As far as I know (I have no circuit diagrams), the models from (real) construction year 12/2018 (those with a stock front camera) have an extra camera control unit.
Both cameras are connected to this and signals are transmitted from this to the head unit (command).
If the bus input and output signals (camera input, steering angle, direction of travel, speed, etc. are needed) have not changed, you should be able to make it ready for operation "like stock".
I seem to remember that the rear camera was also changed.
Question:
Does the stock front camera also have these steering guide lines?
Kind regards.
Stenzel
Integrated car play means you dont have to mount your phone on the dash for navigation like you drive for Uber/Lyft anymore
Also, front camera is really useful when parking into concrete parking blocks to not scratch the front lip, because I feel the front bumper is so far away from the driver its like in the next zip code.
Having additional fail safes progressively lessens/eliminates bad decision pathways lol
Having good UIUX makes ownership experience better
- new grill
- camera
- control module (to allow for the input)
- shop time (bumper removal, wiring, programming etc)
for some reason I think I needed to upgrade the rear camera too if I recall correctly; if that is the case, the cost will be higher.
It will look OEM, but never really act like it. it does the job, but backing in is a LOT cheaper. In fact, if you look at the list for what is included in the 2020 if you want even a couple of them, it starts to get quickly into the "I shoulda just bought a 2020" territory.
- new grill
- camera
"but backing in is a LOT cheaper."
Reverse camera pops up without needing to do anything and it works with the climate controls, audio controls and phone (both steering wheel and centre console
Plus it looks way better!
Maybe you have an other option?
TIA.
https://braybrooks.co.uk/product/ret...-for-mercedes/
Thank you for the link as I sort out in the US. And if I decide to do it.
Cheers.
