AMG GT black series rear wing on a 2016 GTS Edition 1?
Regards
Jerry
If you must change the rear wing think about the OEM GTR wing along with the canards from the Pro on the front would be my recommendation.
AA
To maintain proper aerodynamic balance, any increase in rear downforce should be matched with an increase in front downforce—typically by adding a larger front splitter. Without this upgrade, you risk losing front-end grip during cornering, which can lead to understeer.
The severity of that understeer depends on corner speed, angle, and overall driving conditions. In short: it’s not ideal.
Additionally, increasing your car's aero footprint has trade-offs. More downforce means more rolling resistance and aerodynamic drag, which can reduce both acceleration and top speed. This has grater effect on GT and GTS, unlike the more powerful GTC, GTR and GTR Pro.
When designed correctly, though, with balanced front and rear aero, it improves high-speed stability and cornering grip—essential for performance driving.
That said, if you're upgrading the wing primarily for the aesthetics, that’s absolutely valid and can be a lot of fun. Just be mindful not to push the car too hard through fast corners or at high speeds on straightaways if the rear wing is aggressive and there's no corresponding front aero to match.
You don’t want to end up like Mark Webber
One more thing to consider: the AMG GTS has a narrower rear track compared to the GTC, GTR, GTR Pro, and Black Series, so fitting a GT4 or Black Series wing might look a bit disproportionate on the GTS.
—https://www.youtube.com/watch?v=ZXZaAuyuYmQ(Of course you will not, but just trying to show the extreme case)
if y'all think the best solution for functional downforce for a 10 yr old GTS ED1 that may see some limited track days is what the AMG engineers have delivered with this car, I will leave well enough alone...Thank you all for great info / discussion.
There are two key areas to consider:
- The sensation of the front end feeling light under heavy acceleration
-Optimizing the car for track use
1. Addressing the “Front Feels Light” Issue
First, it's important to identify when this feeling occurs, because that determines the root cause and the solution.
There are generally two phases in the vehicle’s performance spectrum:
The mechanical grip phase, where power delivery and suspension geometry dominate behavior (typically up to 80–100 mph)
The aerodynamic phase, where aero begins to significantly influence vehicle dynamics (usually from 80 mph upward, depending on the car’s weight, shape, and setup)
If the front-end lift or "light feeling" happens below 80 mph, it's likely due to suspension tuning—specifically spring rates, damping, front-to-rear rake, or weight distribution. In that case, adjustments to the mechanical setup are key.
If the issue appears above 80–100 mph, especially under wide-open throttle, then you’re likely entering the aero phase, and a lack of frontal downforce is the culprit. In that case, improving aerodynamic balance—such as by adding or modifying a front splitter or underbody elements—would be the next step.
2. Optimizing for Track Use
Track type and cornering speeds dictate how important mechanical vs. aero grip will be.
If most of your cornering speeds are below 80 mph, mechanical grip is still king. That means optimizing suspension geometry, tires, camber, spring rates, and sway bars.
If you're driving on high-speed tracks where corner entry speeds are above 80 mph (like road courses with sweepers or banked sections), then aerodynamic balance becomes a major factor. In these scenarios, dialing in both front and rear aero to maintain stability at high speeds will significantly improve performance.
IMHO, a GTR wing with a proper front splitter upgrade will be an amazing upgrade without effecting the car's HP too much, "paying" a bit in acceleration targets over 100 mph.
Love to hear the feedback!
AA
If you are driving on public roads and driving at speeds where you are running out of pure mechanical grip, that's too fast for public roads.
The GT R's rear wing provides some more downforce yes but it is not substantial compared to a higher bigger GT wing like APR. To your question on adjusting wing for functionality, that IS how you're supposed to do it, make changes, drive at the limit and then adjust based on the car's feedback at the limit and your driving style, there's no magical preset setting.
I've driven cars with massive imbalance of aero (APR GTC300 wing at the back and no front aero), and on the street and canyons could hardly tell the difference, and only on track with high speed corners could I tell that the car was pushing
AA
The drag forces you to apply more throttle to achieve the same speed and acceleration you’d see without the wing, which in turn raises fuel usage.
Whether you’re driving in a straight line, sweeping through a fast corner, or just cruising on public roads, the reality is the larger the wing and the steeper the angle of attack, the sooner drag will start to build—often at surprisingly low speeds.
For example, when I set the GTR wing on my car to 10 degrees, I could feel the drag coming on as early as 50 mph.
I also spent time running the DC3/U94 wing (the one you have on your GTS Edition 1). Because it has a fixed angle—a one-size-fits-all configuration—it generated noticeable drag even at moderate speeds.
In contrast, the GTR wing offers adjustability between 0–10 degrees, and when set to 0 degrees, it produced less drag than the fixed U94 wing.
This is why choosing an adjustable wing is critical if your driving goals vary between road use, track days, and high-speed events.
Regarding front aero, you mentioned the diffuser, but I’d consider a larger splitter, or as @thebishman pointed out in post #3 above, adding side canards may be all you need to balance rear downforce.
Ultimately, you’ll have to experiment: test a setup, take notes, make adjustments, and repeat until you dial in a configuration that suits both your driving style and the specific track.
Personally, since I prefer the car to rotate and lean toward oversteer in performance driving, I installed larger fixed front splitter extensions. Even with the GTR wing set to a full 10 degrees, the car still exhibits a bias toward oversteer in high-speed corners.
And yes—just because of the larger non-removable front splitter, I absolutely pay the price at the fuel pump.
Add-on front splitter extension. Must be attached to the chassis (not front bumper) to remain on car @ 150MPH and above.
