cleaning inside of windows
Turbo Diesel
i cleaned hte inside of my windsheild and the rear window and i left sooooo many swirls for some reason!!! and i can't get rid of them!
does anyone know how to remove swirl marks without making more swirl marks? HELP!
I use Stoners with lots of clean paper towels, then buff the last bits of cloudiness with a fresh micro fiber towel. I keep one in the compartment in the seat base.
Greg
Greg
Turbo Diesel
Originally posted by awiner
What did you use to clean it ?
i just used windex and a dry terry cloth.
when you clean the inside what do you use, if you clean the inside, and on teh outside what do you use and how do you go about applying and drying???
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
I use stoners as well. Great product. The problem must be in the towels you used.
I use a 100% cotton towel that is only washed in liquid detergeant. Make sure not to wash your towels with softener or it may cause streaks.
05 C320 sport coupe
I always had this prob and the best way to solve it is to wash them in the shade. If you are in direct sunlight, the sun drys the windex before you can remove the film.
Originally Posted by lars
I remember Windex leaving streaks too, but Silvergt02 has good advice. I use Eagle One 20-20 glass cleaner with an MF towel.
Location: Ponte Vedra Beach FL/ Hampstead, London, England
'84 380 SL/ '02 XK8
~One man’s opinion / observations ~
Windex contains ammonia and will turn widow tint ‘purple’ in time.
Cleaning Interior glass:
Wipe glass with a damp waffle weave towel; apply Stoners Invisible Glass™, to 100% cotton Microfiber cloth and rub glass surface with a light to medium pressure (it will dry streak-free / lint-free)
Drying Pattern:
Use a different drying pattern for interior / exterior glass surfaces (i.e. horizontal for interior and vertical for exterior) utilizing this technique you can easily determine the location of any streaking.
~Hope this helps~
Experience unshared; is knowledge wasted…/ Jon
justadumbarchitect * so I question everything *
Drying Pattern:
~Hope this helps~
