Carlsson C-Tronic CD32 installed into my CDI...OMFG!!!
I will wash it up tonight and take some photos tomorrow and send you the file. Pick the one you like!! It would be cool if I post my messages with the same header picture you have - twins of a different color!!
Thanks again,
J. Alan
I live in Kelowna, B.C. I did try to contact you through the link in the profile window but I guess my email ended up in cyberspace as I have had no response from you. I have been in touch with a Mike at the company you mentioned in your post and he sent me a PDF on the installation of the Kleeman with color pictures - it looks pretty basic to install.
I am getting a lot of my questions answered by you and KosherBenz as both of you are running the Kleeman chip while others are running the Carlsson (seems to be hard to nail down a N.A. distributor address and phone number) and now CE750 is providing info about his Renntech chip. The price quoted for the Kleeman was $825.00 U.S. which is converted into Canadian dollars the day you order it. Other costs are import duties and shipping. My local dealer here read me the riot act about chipping concerning the warranty, yet others have advised (including Mike who says their preformance business is located across the street from a Benz dealer) their dealers have no problem with the upgrade. I guess if I go ahead with a chip purchase, I will just have to remove it before any service is performed on my CDI.
KosherBenz - I am a bit computer ignorant when it comes to posting pictures on a forum. Just imagine the same car as yours with the same wheels, except my car color is Pewter. Maybe you can do the color change of your photo and post it!!
Keep the comments coming, guys!
J. Alan
I worry about the Kleemann box because of the 6 connections. The Carlsson one has 2 terminals (goes in near the brake booster area) I think and de-installation would probably be easier. For that reason I would buy the Carlsson. If there is a warranty issue off it comes.
I think I will wait until the revised Carlsson chip is available and make a decision then. For the extra money, it better be good!
J. Alan
and here is one you can add to your signature under userCP
for to usercp type in [img]****[/img]
in the spot of **** insert this link
http://www.mustangmods.com/ims/u/277/3408/155656.jpg
then you will have a sig pic like mine.
P.S. Ur car is dead sexy!
install of the KD box took less than a hour and would be the same to deinstall it. There is some smoke under hard acceleration, but then again.. This is a diesel. I didnt compare it prior to install so i dont know if it more "smoke" than before the install. Noticed a increase of 1-2 mpg after install and quite a large incease in power. More than i expected.
J. Alan, post pics of ur car!
During installation of the ties I looked under the car and am really pleased to report that the 2006 CDi exhaust system is impeccable. In fact I doubt if any after market vendor can improve on the MB system. Straight through. Large diameter. No kinks. Perfection.
I have to trade in my 1986 560 SEL soon. I can now concentrate on my new baby CDi.
I've owned gasser and Diesel force inducted engines and know if the downpipe and exhaust are made larger there also an increase in power or at the least the torque goes max a couple of hundred RPM faster.
The difference between a 2.5" turbo back and a 3.0" turbo back is noticible on a number of forced induction engines.
What's the downpipe look like?
On the 99 300D the exhaust didn't look over 2.5"
Thanx in advance
Thanx in advance
The MB exhaust system is very good and leaves little room for aftermarket improvement. One cat. Two mufflers at the very end of the system. No other emission or noise abatement junk. Perfect.
The Bluetecs are choked with 4 filters. 3 cats. One particulate filter. Presumably 2 mufflers. Think of replacement costs and check engine lights in a few years time.
$5,000.00?
One thing that is very obvious from the exhaust system photos why it is hard to install chrome tips on the goofy curved exit pipe from the muffler. Most of the aftermarket ones twist and dip down under the rear bumper apron and look really cheesy. Kudos for Mercedes though, for designing the exhaust and rear suspension for a very clean and uncluttered look at the rear - so many good looking cars are ruined from the rear view with exhaust pipes, mufflers, hangers, and other uglies in full view when driving behind them.
Another observation - the area along the rear fender lip by the mufflers is a real road debris trap. Whenever I wash my care, I make sure this area is pressure washed as material really builds up here. I have also noticed that there is two rubber grommets along the back of the trunk well (driver side) that are installed from the inside of the trunk. These plugged holes are probably for wiring harnasses for options my car does not have. It you use a pressure washer to clean out road debris along the bottom lip of the bumper, these grommets will blow out into the trunk and you will eventually fill the spare tire well with water. I caught this very early and reserved the plugs and siliconed them in from the outside - so no more blown out grommets!
Any updates on the Carlsson chip you can share, folks?
J. Alan
J. Alan
The owner's manual says not to charge the trunk battery with an ordinary charger. Do you know what it means?
It snowed Easter weekend. I hope it is better in BC.
http://www.carlsson.de/en/tuning/e-k...motor/cd32.php
http://www.carnews.nu/car-news.php?n...article&sid=75
What do you call your third mode of transport in the latest photograph? I am referring to the beauty between the Vette and Kleemann.
I am very happy with my CDi but my wife's Suburban is 7 years old so I have ordered a three quarter ton replacement with the 6 speed transmission (unfortunately not the Allison) and the 6 liter VVT engine. With the GM strike it is going to be 8 weeks to delivery.
The Silverado truck package (diesel and gas) 3/4 ton comes with the Allison transmission as standard.
I got this reply from one of the UK Carlsson representative:
"The C-Tronic performance unit for this engine has now been released after 12 months of testing. There are two units depending on which of the 320 CDi engines you have. The specifications of the C-Tronic units are below;
Car Model W211 320 CDi
Engine type OM642
269 bhp
648 nm of torque at 1600-2400rpm
Do you know which engine is the straight 6? Thanks.
Engine type ON648
240 bhp
580 nm if torque at 2000rpm
The price of either type of C-Tronic unit is Pounds £695 plus shipping cost.
Both are available from stock. Please let me know if you need any further information?
kind regards
Peter
Exclusive Tuning & Design Ltd
29 Slader Business Park, Witney Road, Poole BH17 0GP
Tel: 01202 330650 - Fax: 01202 681433 Reg.Office:as above. Reg.No: 5271395
