Oil Consuption
I have a GL320 and my light came on to check oil level at next refueling.
The car has only 2400 miles on it and i was wondering if this is normal. Do diesel engines burn oil?? Or is this part of the break in?? If so how long till a diesel engine breaks in???
Of interest is the note in the interactive on line manual about oil consumption:
"Depending on how it is driven, the vehicle consumes a maximum of 0.8 l oil per 1,000 km. The oil consumption may be higher than this when the vehicle is new or if you frequently drive at high engine speeds.
You can only estimate the oil consumption after you have driven a considerable distance.
You will find further information about engine oil in the "Technical data" section "
It does not say to what engine this consumption data applies. One can assume all of them at this point.
This is the link. I have not got my GL yet (arrives in a week) but I have found this International manual very informative. You can also search with it in the detail section. Link followshttp://www4.mercedes-benz.com/e/cars/gl-class/betriebsanleitung/flash6.html
Good luck!
The figures on the manual are extreme, mainly to protect the car manufacturer liability against some less than ideal engines.
Trodas, I forgot to mention, there is a known oil sensor problem with the GL 320. You can read about it on the GL forum.
