E320 CDi mod
Old Feb 2, 2009 | 06:58 AM
  #226
Luismbmp's Avatar
S211 220cdi Station Elegance --> 191,4hp/469Nm
Hi, my name is Luis of Portugal.
I have a S211 220cdi (150hp)with gt2256v, with reprogramming.
I have 191hp and 469Nm, but i have a problem, my auto transmission don´t accept more Nm´s (power).
At 2500rpm-3000rpm, it lose some power, and later ace 3000rpm continues with total force even 4500rpm.
Sorry my english it is difficult to understand
Thank´s
Old Feb 2, 2009 | 09:38 AM
  #227
tuikku's Avatar
C200cdi
Thank´s
Hi
In program, there is torque limiter for every gear.
It limits the torque to 450nm level, gears 2->5.
Your tuner had to do some homework.
But it is not a very big problem anyway.
With orig. injectors it is so near to max amount.
~190hp is relative good result.
Bigger cooler might give little more, but is certainly good for your engine.
Rail pressure increasing till max revs gives also little more power.
Old Feb 2, 2009 | 04:11 PM
  #228
Luismbmp's Avatar
Originally Posted by tuikku
Hi
Hi tuikku,
Thank´s for help me.
So, can i reprograming the auto transmission for up the torque limit for 500Nm or more???
It is possible that?
The bigger cooler is good for engine, but have i ''lag'' in future??
You have a very good project, you have a manual transmission or a auto transmission?
Regards from Portugal
Old Feb 3, 2009 | 02:12 AM
  #229
tuikku's Avatar
C200cdi
There is no upper borderline for the limiters.
The line is there, where tuner puts it.
For instance, if he just rise them to 1000nm, and they don´t bother any more.
There is still a one more torque limiter left, which is needed.
Mercedes software is not easy.
If you have "right" kind of software, there are numerous of every kind of limiter limiters.
Bigger cooler does not increase turbo lag at all.
Don´t expect much more power any more with stock injectors.
Your level now is ok, good actually.
As I said, cooler and higher rail-pressure might give a more.
And if your tuner want´s there are very good tools in program to control charger vanes.
With max pulse ration map he can force the vanes more open on max power area.
That gives more air-mass through the engine, which is good during the heat stress, ...and smoke if that matters.
That map is shortly after (smokemap) boostmap.
After cooler you need bigger charger and AMG-injectors.
Old Feb 3, 2009 | 07:33 AM
  #230
Luismbmp's Avatar
Hi tuikku,
AMG-injectors ohhh... that is very expensive
Look the map power
I have problem with auto transmission in red circule (2500rpm-3000rpm)
I will talk with my tuner.
Old Feb 3, 2009 | 08:31 AM
  #231
tuikku's Avatar
C200cdi
Aha
That kind of torque peak is useless.
Ask him to take it away.
It stress the power line, but you cannot benefit it at all.
It is in too narrow rev-area.
Old Feb 4, 2009 | 04:14 AM
  #232
240D 3.0T's Avatar
1982 300D VNT, 1980 240D 3.0T, 1982 300TD
For sure. I'd much rather have that broad, flat power curve below it. A high peak power curve like that is just giving a high power number to impress people, its useless for anything else.
Thats whats known as a "dyno-queen" power curve. All show, no go.
Old Feb 9, 2009 | 12:39 PM
  #233
erh7771's Avatar
As LOB says, reprogramming might be the best alternative for you.
With "hard" chip, that engine gives ~270kw, ++600nm.
And works still very reliable.
It is very close to charger limit.
Bigger injectors cannot give much more.
Exhaust pipe is enough big.
Bigger cooler is always a good purchase.
If there are not any tuner there, maybe then the only alternative is sent the ECU-box here, in Europe.
Your job is only drive and enjoy and make the front wheels suffer.
Charger is originally used on Hino-diesel-engines.
Trucks.
Hi tuikku, Thank you VERY much for your input on this thread and it makes me think about buying a e320 CDI
"...With "hard" chip, that engine gives ~270kw, ++600nm..."
What is "hard" chip? Is it custom tune? If so does your tuner do custom tune if I send him the ECU?
"... that engine gives ~270kw, ++600nm..."
That's over 350hp!!! WOW!!
That's a lot better than I expected out of this car
Old Feb 10, 2009 | 10:49 AM
  #234
tuikku's Avatar
C200cdi
Hi Björnar.
I am closer that you might expect... in Finland.
Maybe the easiest is if you can get a decent remapping from your friend.
~270hp/+600nm is possible.
I don´t personally like at all those "tuning-boxes".
You don´t need to do anything for exhaust pipe, or cats, if they are ok.
Neither new injectors, because there are no "easy" alternative to have a bigger turbo.
And what you first need is a bigger charger and cooler.
I can send pm to you, if you need the address of injectors.
Well, seems that I have made a writing mistake...
Old Feb 10, 2009 | 05:04 PM
  #235
erh7771's Avatar
No problem, do you know anyone that can give a decent remap for the E320 in the states?
What about the person you use? Do you have any contact information for them?
Thx in advance for your help
Old Feb 11, 2009 | 01:07 AM
  #236
tuikku's Avatar
C200cdi
Sorry, I am on the opposite side of this ball.
Remapping is not the problem.
Reading and writing the program from yours cars is.
Surely there must be chiptuners, who can do the job, and have the tools.
Any tuner can transmit diesel-chips from Europe and write it to you cars.
Practically all cdi-MB,s can be done via obd-port.
Reading the stock program from car takes something between 5-10min.
Remapping 15min-1hour, depends on the program.
Re-writing 2-5min.
Very often, the whole thing, under 30min.
Old Feb 15, 2009 | 01:21 PM
  #237
BTML's Avatar
08 ML350
New to MBworld longtime MB lover...
2nd post
I think remaps can be done locally here in US?
I had my 06 E320CDI tuned by Powerchip in California.
Never had a chance for dyno to confirm horsepower but car drove well. Maybe someone else has had dyno?
Old Feb 16, 2009 | 05:13 AM
  #238
Luismbmp's Avatar
Hi people,
my tuner reduse NM´s, but the car have now 168hp and 3XXNM, for a gt22 it is a good power
My tuner had to do some homework.
With this turbo gt2256v i waited 200/210hp and 430/440Nm.
He redused Nm´s and he redused HP too , why?
At 3800-4000rpm i dont have more power
The turbo, MFA, sensor temperature, and more sensor are ok, i made all test and it is ok.
Bye
Old Feb 16, 2009 | 10:36 AM
  #239
BTML's Avatar
08 ML350
Hi people,
Bye
Luismbmp, are you saying your car lost power?
You should feel a difference.
Old Feb 16, 2009 | 10:47 AM
  #240
tuikku's Avatar
C200cdi
Well, you don´t and neither your tuner don´t like this.
He had to learn using WinOls.
Now he is probably using some kind of editing- program (...tuner-pro maybe), so his only chance is change the total amount of torque.
The only chance to make decent custom files, is to use WinOls.
That kind of turbo-swap program is actually quite easy to do...
There is very very good tools to control the turbo in your cars program.
Your cars ecu is similar than mine...
Maybe it is best to try some other.
Old Feb 17, 2009 | 02:17 PM
  #241
Luismbmp's Avatar
Thanks for your mensage.
My turner make very cars in Portugal, very BMW´s 335d with 350hp and 700Nm, M3 with 400hp, seat ibiza 1.9tdi(130hp) with 280hp and more...
But work in mercedes, he don´t have any mercedes with big power.
I think he is learn about mercedes, but if my ECU is a EDC16, many´s BMW´s have EDC16 too, soo i'm confused.
Old Feb 17, 2009 | 02:23 PM
  #242
Luismbmp's Avatar
Yes i feel difference with this repro.
The car stock is
Bye
Old Feb 17, 2009 | 07:34 PM
  #243
LOB's Avatar
LOB
CLK 270CDi
If you want to try MB POWER feel free to contact me
Old Feb 18, 2009 | 03:47 PM
  #244
tuikku's Avatar
C200cdi
My power-maccina now.
Old Feb 28, 2009 | 01:35 PM
  #245
tuikku's Avatar
C200cdi
The engine is back, where it belongs.
New, ported head is coming in Monday.
Hope I´m driving next week.
Old Feb 28, 2009 | 04:02 PM
  #246
240D 3.0T's Avatar
Why did you have to take it out?
Old Feb 28, 2009 | 04:20 PM
  #247
harkgar's Avatar
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
Mr. Tukkui does it daily to build up his muscles.
Isn't he some mechanic?
Old Mar 1, 2009 | 12:59 AM
  #248
tuikku's Avatar
C200cdi
I had a engine break down.
Connecting rod bearing, cyl 2, look above.
One screw was bad and don´t last.
I bought this as new, so the bad screw must be there all the time.
I heard the sound of it for a long time, but I did´t want to believe that it is even possible to have a any "building false" in MB engine.
Well, it costs new crankshaft and rod...
...And lots of work.
The other bearings were in very good shape.
So, still there is not too much torque. (~600nm)
Also clutch and flywheel were ok, no slipping.
Old Mar 1, 2009 | 10:16 PM
  #249
240D 3.0T's Avatar
I see the bearing damage now. How do the pistons and valves look? No heat damage?
Old Mar 2, 2009 | 04:20 AM
  #250
tuikku's Avatar
C200cdi
No damage.
In fackt, they look surprisingly good and clean.
Especially head, with no cleaning.
Same to pistons.
You have already rated this thread Rating: Thread Rating: 4 votes, 4.00 average.
