300SD stalls, won't go over 40 mph
Old Feb 26, 2010 | 02:30 PM
mk52611's Avatar
83 300sd
New module replaced last month when car stopped running altogether. Glow plug light wasn't lighting up. The car still didn't run right after repair, bogging down at 40, but the light came on and went off. Now it doesn't come on altogether. Glow plugs were worn, replaced & didn't solve the problem. Car is now stalling after driving a few miles, just before stall the speed drops down to 15-20.
Need help ASAP, mechanic can't look at it for another couple of days. It took a week just to get the module installed.
Old Feb 26, 2010 | 06:06 PM
TMAllison's Avatar
09' E320
Go to dieselgiant.com and follow the GP testing proceedure for the W123 to solve the GP light.
The stalling is probably restricted fuel flow or a leak. R&R both filters and check the manual primer pump for leaks. If wet, replace. Could be a clogged tank screen also.
How cold is it where you are?
Old Feb 26, 2010 | 06:35 PM
240D 3.0T's Avatar
1982 300D VNT, 1980 240D 3.0T, 1982 300TD
Same on fuel filters and tank strainer. When were the valves last adjusted?
Old Feb 26, 2010 | 06:50 PM
mk52611's Avatar
83 300sd
Replaced all fuel filters, ran fine for a few minutes, then stalled coming out out of a stop. Checked under hood and manual primer is wet. Doesn't help priming it again & tightening, still won't start.
When cold, the car fires up right away. After it stalls, I can't start it again for several hours. I've taken this car to two German car specialists who adjusted the IP despite telling them I've never adjusted valves. First visit was 2 years ago, then a different shop one year ago. No one has ever diagnosed it as needing valve adjustment. I have no idea when it's been done, the last owner didn't know. Another shop 8 months ago gave up on it, was smoking excessively (and still is).
And now another shop. The module was definitely bad, but no reason was given for why some of the terminals "melted". Car is in So Cal, not getting below 40 at night.
Old Feb 27, 2010 | 07:29 AM
240D 3.0T's Avatar
Valves must be adjusted every 12k miles or every year. Performance and economy suffers greatly if its neglected.
Old Feb 27, 2010 | 01:57 PM
mk52611's Avatar
83 300sd
When I first bought this car, I found the dieselgiant website and replaced the valve cover gasket, but the clearances were ok. I'll ask the current shop i'm using to look into it. They've worked on a few other MBZ diesels in town. Now the only problem is getting the manual primer pump...they use napa and they couldn't find the part.
I'm not exactly a newbie with these cars, but I prefer someone else doing the work when possible. I used to have an account on this board, but couldn't access it.
Old Feb 28, 2010 | 12:40 PM
TMAllison's Avatar
09' E320
A valve adjustment on your engine is required maint......
The new style primer pump is much better than the old design and its pretty easy to R&R. WorldPac should have it.
Old Mar 23, 2010 | 03:01 AM
torokubota's Avatar
mercedes 300DT 83, 300DT 85, E300D 96
I would say you are running out of fuel -for example--- in tank screen pluged w/ crud/ filters need changing. diesel is all about getting fuel.--- Aloha tk
Old Apr 21, 2010 | 03:59 AM
Cameron E. Kay's Avatar
Honda Civic
All vehicles should do this, i mean stall when it gets to the speed limit, i dont see the point in cars going any faster when all it does is cause accidents and fatalities.
Old Aug 9, 2010 | 02:16 AM
Komandant's Avatar
'82 300sd Turbo-Diesel, '02 VW Jetta+Golf TDI, '03 VW GTI 20th Ann Ed.
Old Aug 9, 2010 | 11:06 AM
240D 3.0T's Avatar
Sorry, you fail to grasp the concept of freedom. If you want everyone to be forced to follow the law to the letter by big brother, you should build a time machine and travel to 1943 Germany.
Old Aug 24, 2010 | 12:34 PM
transferred's Avatar
08 S65, 06 M3 CS(stick), 02 BMW X5 4.6iS, 07 R1 Raven, 08 F-450 4x4, 08 CooperS JCW
Originally Posted by Komandant
you and cameron fell out the same "special" tree I see.. go to a non-car site....
