Deep water
I have an '06 cdi. I was driving in heavy rains and was going through some deep water. I drove through similar deep water about 2 weeks ago with no problem. normally, a diesel engine doesn't have that much problem with it. But this time, the car stalled. I was out of the water and trying to drive into a driveway (slight incline). I tried waiting for a couple of minutes and trying to start it again and it doesn't crank at all. when I put the key in the ignition, i turn the key and wait for the glow plug light to turn off, then, try cranking it. The lights that are showing up, i don't know. so a couple of questions....
1. which lights are supposed to be displayed when starting the car. if i know this, then i can know for sure which lights remain on. that may help to diagnose the problem.
2. There is not even a sound from the engine when I try and crank it So I am assuming it is electrical. The battery seems fine. could it be the starter fuse maybe?
Any help would be greatly appreciated! thanks!
Electrical gear such as starter motors ,alternators, relays , sensors & electrical connections do not like being immersed in water.
In my humble opinion it is a mistake to drive through deep water. You are probably lucky not to hydraulic your pistons.
I would open your bonnet to the sun or fan for a day or two to see if things dry out. Your air filter could be saturated & need replacing. Your starter relay could be wet.
With the ignition on & before starting I would think that the ignition light ( low system voltage) & low oil pressure light should be illuminated.
Good luck & let us know how you go.
240D 3.0T: This is not a perpetual thing, I was driving in heavy rains and was kinda lost and made a wrong turn (in the worst sense of the phrase) and here I am.
I will keep everyone posted. Tomorrow I plan on removing the underbody splash covers and have a look underneath to see which components look waterlogged. Thanks again for the replies....any other opinions would also be a great help. Thank you.
Any ideas as to what this could be caused by? The car was left on car ramps for over 2 weeks. The battery was left disconnected as well during this time. Any help would be appreciated. Thanks.
