OM642 reduced performance after WOT
This happened twice: first time it happened was accelerating up a fairly steep bridge, second time was overtaking on the highway. Both were around 70-80 mph. Restarting the car after coming to a stop resolved the issue both times.
Any ideas what could cause this?
The code triggers soft limp and if continued, it will trigger CEL.
Either way, coffee grinds are not the best for troubleshooting those vehicles, so better get a scanner.
I've got a brand new intercooler and one new charge air pipe. The other new one kept popping off (it's aftermarket, sadly FCPEuro doesn't have an OEM one for that side) so I went back to using the old one, which seems to have a small crack in it so I bet that's the issue. Hooked up my scan tool earlier to confirm:
Thanks all for your quick replies! I'm going to try fiddling with the clips on that new aftermarket charge air pipe and see if I can get it to stay on, I bet the old one is leaking thru the crack. It's a bit oily in that area.
