Cricket sound in my E coupe
I've been with my E coupe for less than two months. Well, I have a kind of noise that seems like a cricket sounds in the car and I can not know what it is. It seems as if coming from the dashboard, but I'm not sure.
I pass a video I uploaded to youtube so you can hear it, but in this video does not sound too. Other times it sounds more.
http://www.youtube.com/watch?v=ORBGDx61H-g
I think that one appreciates it in the second 10 and the second 34 and until the end of video
Can you think it might be?
If you press the black flat plastic piece infront of the dials it flexes, when you're driving along press it down whilst you go over a bump etc and you'll notice that the sound goes away
loll wow this is soo funny, mine does the same crap and i do the same thing, i get irritated by things like that
And will it have solution????
Anyone had it addressed/repair?
Spoke to the tech that did the repair last time and he said they took the pod & dials out and put a felt lining in there to stop the rattle/flexing which has worked to a certain extent but not fully - when the plastic flexes upwards the creaking/cricket sound starts all over again, not as loud though.
They've said they'll replace the entire pod this time plus re-line inside of it as they did before and see if that helps.
Quick picture to point it out to anyone who may or may not get what I'm on about..
I hear a voice on my dash display as well. I have uploaded a video on youtube where you can hear the actual noise. Can you please check it and tell me if is the same cricket sound that your hearing?
Lease fins below the youtube link:
http://youtu.be/EKKwuW4xL4A
Thank you in advance
Louis
One test to do when your car is stood still, knock hard on the top of the dash pod above the steering wheel, see if it replicates the noise, if it does then you will have the same problem which I have - at the minute I can't see any other resolution to it than replacing the dash.
Your a life savior. Its 5 months now that i am trying to find from where this noise come from. I took the car to MB tech but they couldn't find it. And you found it. It is the upper pad as you said.
Thank you very very much
