WTB: LED License Plate Housing for MY11 - E350 coupe
Please tell me where can buy a pair of those? I want to replace the whole housing instead of the bulbs.
Is E350 coupe same as C207 or W207? What are the differences?
Thanks.
http://www.ebay.com/itm/W207-W204-W2...item3f11f731b7
I emailed to this ebay seller about 5 days ago. He replied to that these led license lamps DO NOTfit the E-coupe.
I don't understand why he put these lamps are applicable to W207? Maybe, did he confuse with C207 and W207?
I went to the dealership yesterday and check the OEM housings between the coupe and the sedan, it looks like the are the same size.
Anyone bought these bulbs from this ebay seller and install without any problems?
Also, you can call a MB parts dealer and see if the part#'s are alike for the W207/C207
Too much confusion for W207 & C207. Is W207 official to Mercedes?
I just ordered a set of LED License Lamp housings from an ebay seller from Hong Kong.
I'll let you guys know the outcome.
Anyway, anyone have pictures how to remove the existing OEM license plate housing?
Ty one more time
http://www.ebay.com/itm/2pcs-18x-WHI...ht_5964wt_1114
Looking for $35 shipped. Pls PM if interesterd, Thanks guys!
EXCEPT
you have to pull "slowly and carefully" the black plastic piece out (using a small screw driver and insert into the little slots) under the chrome strip (under the MB trunk emblem) in order to remove the whole unit of the OEM license lamp and re-install the LED license lamp unit.
Once you pull down the liner of inside the trunk, put your hand in and squeeze the legs to loosen the license lamp.
You don't have to take off the trunk liner.
