E550 Scheduled for ECU Tune....Kleeman or RennTech?
- The Kleemann has slightly less power but is significantly cheaper, almost half the price
- The Renntech tune was recommended by my dealer because they "don't use a bolt on the ecu", it also has about 22 extra ponies, but is twice the cost.
Can anyone share experiences with either tuners?
1) I read some very negative reviews on Eurocharged online about both their product and customer service. I was also advised against the Eurocharged tune by several others. I'm not saying what I heard was true, but the stuff I've heard makes me uncomfortable to use their products.
2) Yes, the dealer is an official RennTech dealer and one of the largest in the US. They have assured me there will be no problems as long as I use them going forward. They condone the ECU tune and even said it was a mild tune.
3) Yes I believe this is the same bolt thing. I don't know how RennTech gets around this, doubt they would share their method anyway
I'm glad to see a rep of Eurocharged online though, and that they do participate in the exchanges of opinion on this forum.
Our engines also have 3rd party companies that sell their modification parts to replace our OEM parts ranging from ECU, EGR, deletes, and etc. I cannot say about Renntech, Eurocharged, and etc on what they do. But I can tell you that these mod parts used on our engines cause more problems than they are helping. In they past when the software on the ECU was not highly encrypted, these companies could still hack and decrypt the source code to modify the fueling tables (hence able to claim for hp increase) and then to do other things involving the aftertreatment components they have removed. But these days, our software is highly encrypted and those companies can only use their guess to override the fueling command. Their mods so far almost to most of the times are empirically based, and rarely physics-based, which means you will see hp increase (of course more fueling == more hp) but in the long run you may face other problems. One of the examples that I have see happen is that the ECU has been flashed with 3rd party software to give more fueling, then more fueling == more soot, but the soot filter regeneration may still be based on the original schedule (which the 3rd party guy may ignore to care), then the soot filter receives more soot in a given interval than it can clean (regenerate). The result is the soot filter becomes clogged, the dealer finds the mod and the warranty is denied, then the customer has to pay for the repair, wwhich I think would be about $6k for parts and labor.
This is jusst my 0.02 anyway.
Most of us tuners have already decrypted the ENTIRE ecu and have access to every map that MB uses (multiple thousand). To further prove that point google some of our turbo projects such as the turbo srt6 or turbo C350. Those were done with factory ecu, not a piggyback. Also check out the E55 forum where we modify fueling tables on a daily basis as stage 2+ cars need upgraded injectors.
Second, the car runs pig rich from the factory. Almost all tuners will lean out the mixture and not richen it. You make more power that way, not by adding fuel.
We are on the forums every day, helping out with various things. We have tuned so many cars on this board that im surprised you are seeing negative experiences. I would suggest venturing out from the C207 forum and seeing a few of the others. You will see a ton of happy customer posts for us. The only negative ones I am aware of are years old.
Either way TUNE THE CAR! Its night and day different and probably one of the best things you can ever do to it! Both renntech and Kleeman are great companies and you can't go wrong with either one!!! The reason they use the bolt is to not have to physically open the ecu. We have seen many problems with that method as the boards were shorting. We drill a hole then have a device to touch the one pin we need to finish the tune. We then cover the hole with epoxy and paintmatch the ecu color.
Recent review:
https://mbworld.org/forums/w212-amg/...ale-899-a.html
Oh, and our tune is on sale for $899
Recent review:
http://www.benzworld.org/forums/w211...or-2-year.html
I asked a few others and came back with a negative impression. Obviously people usually post to complain but the bigger thing for me, is that my dealer will take care of the RennTech or Kleemann tune but not the Eurocharged one. To me it's just piece of mind for the warranty if the dealer takes care of it.
I see your link and raise ya
Some people you just can't make happy. He was banned from almost every forum. But there are always two sides to every story. http://www.*********.com/showthread....-the-douchebag
Yes, we used to open the ecu (no bolt or hole) but found in the long run that to be a risky problem. I can only speak from our experience of coarse and not for the other vendors.
That was also why I said in my post that I cannot say about what Renntech and and Eurocharged do in their mod algorithms. But, I could just say about what some of the companies which mod our products, for what they usually do. Being able to decrypt the OEM software is one part, there are other parts which are highly essential to making the engine operation robust, too. I am not here to open a debate, though.If you meant by "rich" == "rich mixture" between fuel and air, I am not sure I can agree. This is because the US has one among most strictest emissions regulations in the world, by EPA, and especially in CA where CARB reigns. Rich mixture will result in a lot of things including emissions exceedance, not too mention poor fuel economy. At every engine operation point, there is a certain air-to-fuel ratio (AFR) which the engine needs to meet in order to produce the required power for a given load while still remaining economical and emissions compliant. So, having said that, the AFR can change depending on the engine operation mode. And if what you said about the OEM software was generally rich, they would not have passed EPA and CARB emissions tests. In my experience having seen our ECMs modded by those companies, it has been otherwise; the emissions are through the roof and the fuel economy is worse. However, I by no mean am talking about your mods but sharing what my experience with other members. And it is great if your mods are physics based that the modded engines are working robustly and that your customers are happy.
BTW, I neither had any negative experience with your mod nor said that I saw any negative experience with your mods.
Recent review:
I did Eurocharged and Sprint Booster. Oops put an K&N filter too! Next purchase Prior Design PD550. Wheels undecided, got any ideas for suspension?
