Filling gasoline problem
I phoned the dealership this afternoon, and he told me it happened to some of the E class (not sure about the other classes). He suggested that I should pull up the trigger half inch from the gasoline filling inlet and the problem will be solved.
Anyone has this issue or he was just BS? My car is still under warranty, what is the problem of the car?
I suspect your trouble was with the vapor recovery/overflow system on the gas pump. I have had the same problem on other cars particularly when in California.
His suggestion to raise the filler nozzle up some is a fix at the expense of partially defeating the vapor recovery/overflow system.
The only problem is how long I have to wait for a new appointment.
Some gas pump nozzles are getting old on its rubber seal, or the gas station calibrates the nozzles too sensitive for any leak, or some nozzle designs which the gravity would tilt them down in an angle that it is easier to break the seal, etc., etc.
It did happen on my E Coupe when I first got it; one gas station attendent helped me to push the gas nozzle a little further into the gas tank opening and used his hand to ensure the gas nozzle rubber has a complet seal to the gas tank opening. That solved the problem in my case.
Yet, occasionally, some gas pump nozzles had a really banged-up old rubber seal, which no matter how I tried it would still give me the problem. In that case, I just reminded myself not to go back to the same gas station and use the same nozzle again.
Hope it helps.
I tried different nozzles but the problem still exists. Anyway, I already made an appointment with the dealership next week, I will let them diagnosis the problem. Fortunately, this car still has factory warranty, otherwise, if something needs to be replaced, it is gonna to cost me a lot of money.
I will report how it goes.
http://www.autoguide.com/auto-news/2...fire-risk.html
They concluded that the gas station that I used (which is near my house) were having the bad gas nozzles.
In normal practice, I insert the gas nozzles all the way to the gas inlet from the vehicle to prevent any gasoline spillage in case of overfill. My old W203 had no problem at all. I think it is most likely this C207 does not accept this gas station gas nozzle.
I will try your method again once the gasoline is low. Thanks.
