Navigate from contacts / address book -> Android?
Is anyone out there having success navigating to addresses pulled in from an Android phone?
Hope this helps.
I entered a 'Test Contact', in Gmail Contacts, putting complete address in the address field.
I entered a 'Test Person' in Gmail Contacts, and clicked the ... in the Address Field, and entered each field.
They both display complete address in the address field in Contacts in Gmail, but if I expand the ... on each, the only one that displays in each individual field is the one that I entered that way.
In the Mercedes, the only one that shows each field in the appropriate place is the one that I entered complete data in the address field. The one that I entered each field individually only shows data in the address line in the Mercedes display of the contact address.
In both cases, I get an error from the Mercedes that the address is incomplete.
My car is in the shop getting serviced but I'll update you when I get it back.
Just out of curiosity, what COMAND software version are you running?
This is strange. Seems it should work.
[EDIT]
I found how to go into the Engineering Menu. Didn't see anything saying 'Command Software Version', but I did find under a menu of MOST Information, an INIC FW Ver of 01.10.07, with INIC HW Ver. of 0s81050E. Does that answer your question?
Have you had oppty to test your system again?
[EDIT]
Yep, tested it this morning and it worked just fine for me.
