PARTS! Rotors warping. Cost
Old 11-04-2014, 04:02 PM
turaHvrR's Avatar
2012 Mercedes E550 Coupe
Hello,
Car: 2012 Mercedes E550 coupe
I have been through my first set of rotors due to warping within 7k miles(replaced under warranty one time goodwill). within another 7K miles i have started feeling the vibration again. I cannot tell if I am driving the wrong way or the parts are just prone to warping. The dealer claims it's my driving and that I live up on a hill that's why. However, I do not live up on hills and I do not drive it any differently than I have driven my other cars. Normal to spirited driving 20% of the time.
Every other car that i have had, the rotors have lasted me over 30k miles without warp. I cannot see myself spending over $800 dollars a year on new rotors and pads when I have over 80% Pads left.
With that being said...
I found http://www.mymercedesparts.com/. I am wondering if any of you have used this website and if they are a legitimate OEM parts dealer?
http://www.mymercedesparts.com/parts...omponent=ROTOR
Any help is greatly appreciated. Parts seem a lot cheaper than getting them at the dealer.
Old 11-04-2014, 04:16 PM
zulumerc's Avatar
ECS Supercharged C6 Corvette& 2012 E550 Coupe
OEM rotors suck its a common problem. Go ahead and order the centric rotors and stop tech pads. I used those on mine.
4 rotors 8 pads shims and sensors parts came in under 500
Old 11-04-2014, 05:40 PM
turaHvrR's Avatar
Thanks i will definitely look into those. thanks for the quick reply. In general where is a good site to shop for Parts such as those?
Old 11-04-2014, 05:43 PM
F1BHP's Avatar
sl600
Stock rotors can only take a few hard stops in succession before they overheat. My rotors caught on fire after just 4 laps around SPA
Old 11-04-2014, 05:46 PM
turaHvrR's Avatar
Wow!! and mercedes completely denies that its a weak product!!!
which rotors do you use now?
Old 11-04-2014, 06:59 PM
F1BHP's Avatar
sl600
Went with the Brembo BBK 405mm front and 380mm rear. I track alot so to me the brakes are my most important part of the car.
Old 11-04-2014, 07:00 PM
turaHvrR's Avatar
Old 11-05-2014, 02:08 PM
zulumerc's Avatar
Rockauto amazon etc
Old 11-05-2014, 02:26 PM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
stock rotors should be fine for daily drive...
autohausaz.com... located in AZ so fast shipping and no tax...
Old 11-06-2014, 02:53 AM
chrisdabeast7's Avatar
C300/E550 coupe
I got the same problem too, it sucks. Everytime I brake, there is a vibration and it feels very shaky. I've already changed rotors twice already, thinking about getting aftermarket rotors this time around. Let us know which ones you get!
Old 11-06-2014, 10:35 PM
kc2ntlh's Avatar
S 560, C 63 S Cabriolet
Hello All. Add me to the list of those having the warped rotors that cause vibration when braking. I too am searching for an aftermarket solution. Otherwise, the car has been rock solid.
Old 11-25-2014, 05:28 AM
kc2ntlh's Avatar
Thumbs up Update: New X-drilled Rotors and Ceramic Pads
I went with the following upgrades, and now I'm all
105.13410
Centric
2012 Mercedes E550 Brake Pad Set
Rear Brake
Brake Pad Set
105.16520
Centric
Front Brake
Brake Pad Set
128.35115
Centric
2012 Mercedes E550 Brake Rotor
Rear Brake
Brake Rotor (2)
128.35118
Centric
Front Brake
Brake Rotor (2)
Total parts cost was $489 shipped from xartsgeek_dot_com
(replace the x)
Old 11-25-2014, 12:02 PM
zulumerc's Avatar
Heads up to anyone buying the 128.35115 LR rotor, mine was made around May of 2014.
Centric had machined some of the rotors incorrectly I got sent 4 of them all of them were wrong. I finally contacted Centirc and figured it out by sending pics of the rotors. I ended up buying one that was made outside of that date range. The driver rear rotor would not seat all the way flush it was contacting the backing plate near the lip by the E-brake drum causing the rotor to bind and smoke, it actually turned blue from the heat.
Old 11-26-2014, 01:11 AM
TopGun32's Avatar
I have gone through 2 sets of OEM rotors.. I had vibration on the front rotors.
After inspection of multiple rotors... my conclusion the drivers front caliper does not wear the rotor evenly like the passenger side.
I truly believe that there the problem is only the drivers side front caliper. I will try to take pics.. but its obvious to me the contact to the rotor is not the same when comparing drivers side and passenger side. Its even contact but not smooth.
Ordered all my aftermarket parts through Amazon and Ebay.. but first I went to the Stop Tech website to find the correct rotors.
If you search my post.. I went with drilled rear rotors from Stop Tech/Centric from a C350. Again search parts numbers and you will see the share the same rotor size but one is solid and other crossed drilled.
I went with EBC pads.. again search right pads for the front.
So far.. 4 months later.. no vibration.. but still feel not completely glass smooth.
Next I will balance tires to see if I can pin point.
14.2 inch front rotor will make a easy swap to c63 standard caliper or W211 E55/63.
Old 01-31-2015, 07:46 AM
Pennetta's Avatar
19 E53 AMG Cab, 21 Land Rover Defender 110S, 20 LR Discovery HSE, 23 Ford Bronco 2dr 7spd Manual
Are there any MB service bulletins on this issue?
Are there any MB service bulletins on this issue? I have it too for the third time. Going in to dealer on Monday and would like some evidence.
Old 02-15-2015, 01:05 PM
Pennetta's Avatar
Had the brakes replaced at my cost but it feels so much better now. Worth it.
Quick Reply: PARTS! Rotors warping. Cost
