W207 facelift conversion headlight issue
Old Nov 1, 2016 | 09:32 AM
hkhan's Avatar
e220 cabriolet
Hi all,
I have done a facelift conversion on my 2012 e220 cabriolet however, I am really stuck on the headlights, i have taken the car to a number of electricians to try and get them powered up but they have all struggled. If anyone could please help me with this it would be greatly appreciated.
Thanks in advance
Old Nov 2, 2016 | 03:23 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to C207 forum...
Xentry might be needed for version coding...
Old Nov 3, 2016 | 05:00 PM
ob2s's Avatar
E-Coupe 5.5 | 1956 190SL
Originally Posted by hkhan
Hi all,
Thanks in advance
Tell me the part number of your old headlights and the part number of the new.
Old Nov 4, 2016 | 11:25 AM
hkhan's Avatar
e220 cabriolet
Hi,
the new headlight part number is a207 820 09 59kz and the old one is a207 820 02 59kz.
Many thanks
Old Nov 4, 2016 | 11:42 AM
ob2s's Avatar
Hi,
Many thanks
So you live in a Right Hand Drive market ?
This is the new one right ?
And this the old one ?
On the old one, was the low beam High Intensity Discharge or H7 halogen ? Also do you still have one of the old headllights ?
Old Nov 4, 2016 | 11:47 AM
hkhan's Avatar
e220 cabriolet
Yes right hand drive, yes the first was the new part number. They were xenon headlights so I assume high intensity discharge. I don't have the old headlights unfortunately
Old Nov 4, 2016 | 11:54 AM
ob2s's Avatar
The new headlights are installed in the car already ?
Old Nov 4, 2016 | 11:57 AM
hkhan's Avatar
e220 cabriolet
They are fitted but the only thing that works are the indicators
Old Nov 4, 2016 | 12:20 PM
ob2s's Avatar
So as you can imagine the wires in the harness don't match the headlight. Before you had a low beam/high beam combo controlled by the ballast, now you have 2 circuits, one for low and one for high. The low beam circuit wire is there but connected to the wrong prong on the headlight. There is no high beam wire in your harness, but there is a prong on the headlight for it. There probably isn't anyone (outside hella and mercedes) that knows more about these headlights than I, and that doesn't include the very expensive dual led headlight of which I know nothing. At minimum, you have to swap the wire the is fat yellow on one side and yellow black on the other currently connected to pin 6 on the headlight to pin 4. Pin 6 on your new headlight is a dummy pin. This should get your low beams working from the switch, HOWEVER, you will get a message saying the low beam is out. You have to splice an H7 resistor in there to compensate for the resistance loss of the LED. In fact you'll get all kinds of messages I imagine, depending on if you had LED daytime running lights, or side markers that aren't on the new bumper. So at a minimum just to get on the road at night, you'll need to swap the wires I mentioned above. Sorry but you stepped into a CF.
Old Dec 8, 2016 | 08:27 AM
Asghar.ali262's Avatar
Mercedes E Class Coupe
W207 Conversion
HI Dear,
i am converting my W207 2011 to 2014 Facelift Version with Xenon lights,front Sam,Front & Rear Bumper,Side Skirts and Back Lights,
now the problem is that the headlights are not working,i have installed the new SAM but no good,
Could you guide me what should i do how can i make this work or is their anything missing,
Regards
Old Dec 8, 2016 | 09:49 AM
ob2s's Avatar
Originally Posted by Asghar.ali262
HI Dear,
Regards
They are not called Xenon. 2014 is LED only, or LED/Halogen. You will need to ask Chris the Swede about the SAM installation. There is a wiring harness converter he has, and it also takes programming that he says he can do remotely.
Old Dec 10, 2017 | 04:55 AM
Laci183's Avatar
w207
hello! I' like convert my MB w207's halogen headlight (A2078204861) to static led headlight (.A2078208061) Can I change cable harness? Can you help me? Thx.
Old Dec 10, 2017 | 08:25 PM
Camber53's Avatar
w207
Pm me I will be able to do it
Old May 7, 2024 | 12:11 AM
Jae Calderon's Avatar
2004 sl500 r230
would like more info about this retrofit to the full led headlihhts, only turn signals work rt now . I’m new can’t pm yet if you could reach out to me ?
