new big calipers for e250 convertible ?
Old Jun 24, 2018 | 03:28 AM
dudeasca's Avatar
e klass cabriolet 250 cgi 2015
hello
i wanna change my stock brakes( i hate the look on my stock calipers ) , with the ones that are bigger
do you know if it will fit my car with amg package ? plug and play ?
Old Jun 24, 2018 | 04:01 AM
cm60k's Avatar
These calipers are not AMG's..!,
do you want to install them in your conv. E250..??
-;ZAYED;-
Old Jun 24, 2018 | 04:06 AM
dudeasca's Avatar
-;ZAYED;-
i don 't care if it s not amg
i just want bigger callipers , to paint it red
if it s direct fit on my e250 i will replace it
that why i asked if this 2011 e klasse big calipers will fit my conv e250
Old Jun 24, 2018 | 04:37 AM
cm60k's Avatar
Ahh, i see,
from which E class you found them.?, cause i think these calipers for "W205/C-Class",,
-;ZAYED;-
Old Jun 24, 2018 | 04:39 AM
dudeasca's Avatar
Ahh, i see,
-;ZAYED;-
the ad i found says e klasse 2011
i think sedan , but waiting for his answer
Old Jun 24, 2018 | 05:03 AM
cm60k's Avatar
The photos shows these for "W205", and the MB part #'s for these calipers:-
L #: 011 421 91 98" or "011 421 97 98"
R #: "011 421 92 98" or "011 421 98 98"
no problem, will wait for his answer..
-;ZAYED;-
Old Jun 24, 2018 | 01:33 PM
dudeasca's Avatar
-;ZAYED;-
thanks mate
unfortunatly he doesn't know from what e klasse it comes
Old Jun 24, 2018 | 01:37 PM
dudeasca's Avatar
i searched also on google with the part numbers..indeed they are from w205 c klasse....
but i really wanna know if it will fit my convertible e250 facelift
love the look on them if i paint it red with mercedes benz writing on white
Old Jun 24, 2018 | 05:37 PM
cm60k's Avatar
Yeah, these really looks awesome,
i have sense that this nice W205 front calipers will fit to your knuckle,
but i don't want you to tossing money for nothing,
to assure fitment, prefer to measure your caliper hole distance,
from center hole to center hole, and ask the seller to do so,,
cause MB got differ hole measurements, depend to the knuckle M/Y spec..
-;ZAYED;-
Old Jun 25, 2018 | 07:23 AM
400ixl's Avatar
E250 AMG Sport Convertible
Thats not the only measurement you need. You will also need to know if the offset is the same to align with the disk and is the caliper height correct to place the pad correctly on the disk. Do these calipers also run the original disks, or are they bigger? If so does this change the dimensions you need.
Old Jun 25, 2018 | 07:41 AM
cm60k's Avatar
Why need to know the offset of the hub or even of the Rotor, if he will go with calipers & Rotors together..!
if he will install the calipers & Rotors, the main point with the distance between caliper hole to hole,
MB always uses the same Rotor center bore & bolt pattern on all their "saloon/coupe/cab./conv./sport",,
that's why i'm not worry about offset/align of the caliper or even Rotor..
-;ZAYED;-
Old Jun 25, 2018 | 07:48 AM
400ixl's Avatar
Not talking about the wheel/ disk PCD or C/Bore here.
If the offset of the mount is different to the original car the caliper is from then alignment will be out even if the disk is replaced. Seen it too many times when people assume it will be the same even on the same model, let alone across different models.
Measure twice fit once.
Old Jun 25, 2018 | 08:34 AM
cm60k's Avatar
Usually "W205" using lower Rotor offset, which is (51mm), and "C207" uses (64.5mm),,
that depend the caliper width & knuckle design,,
"C207" sharing the same knuckle with "W204", but the "W205" has a differ shape,,
Rotor offset/height will be the main thing that makes wheel will goes more forward than it should or not..!
those calipers looks like W205 C300, if so,,
the offset will not be the issue, cause it's (51mm), i don't think Rotor will goes outward, that much for wheel caliper clearance..!?!
-;ZAYED;-
Old Jun 25, 2018 | 10:03 AM
dudeasca's Avatar
the distance betwen those 2 holes is 140mm
Old Jun 25, 2018 | 10:16 AM
cm60k's Avatar
I see,
probably & hope yours are the same, did you measure your caliper holes..?
-;ZAYED;-
Old Jun 25, 2018 | 10:32 AM
dudeasca's Avatar
I see,
-;ZAYED;-
not yet
tomorow i hope
