Steering wheel problem
Old May 9, 2019 | 12:31 PM
rogerschnabel's Avatar
sl500
Smile Steering wheel problem
hello everyone
My 2012 E 350 Cabriolet steering wheel is up at the highest position It will go in and out but not down Is this a major fix or something that can be corrected more easily
Old May 9, 2019 | 12:39 PM
SMG_CT's Avatar
2013 E350 4Matic Coupe
Lightbulb Information about this problem
I had this same problem with my 2013 E350 Coupe. This is how this problem was resolved:
I researched the online forums to understand this common problem:
from BenzWorld forum
from MBWorld forum
I contacted the local Mercedes Service Department and spoke with the lead Service Advisor who explained that this was a common problem with the C207/A207 and W204.
He advised me to bring the car in for service. He tried to fix the problem by hitting the top of the steering wheel with his fist while holding the adjustment lever down to try to move the wheel. This did not work.
The car was then taken in for service in the service department and did the following service:
  1. Reset the steering-wheel adjustment via the MB StarTech system
  2. Applied the new SW noted in the TSB for this problem (see attachment below)
  3. Degreased and then re-greased the gears for the steering wheel adjustment
The service advisor also recommended that I deactivate Easy-Entry Feature (see attachment from MB owners manual below)
The Mercedes dealer, Mercedes of Fairfield (A Penske-owned dealership), did this service as complimentary (no charge) in hope of earning my service business. They also went through the car and could find nothing to fix. It was recommended that I would need a brake service for the front brakes in ~15,000 miles. I sent an email to the Service Manager thanking them for a great service experience.
There was a MB TSB on this problem (see attached photo)
Old May 10, 2019 | 08:36 AM
Flash Gordon's Avatar
2003 E500, 2004 G35X
SMG CT is very helpful! I have deactivated easy entry of all my cars for many years to reduce the wear and tear as suggested by the service manager above.
Old May 11, 2019 | 11:59 AM
sl500
Thanks SMG CT ypur reply solved my problem the steering wheel now works in all positions up down in out
Roger
Old May 11, 2019 | 01:25 PM
SMG_CT's Avatar
Question That's Great News
Roger
I am glad the information was helpful.
Did you turn-off the Easy-Entry option for the steering wheel?
Old May 12, 2019 | 07:43 AM
aaron987's Avatar
2015 E400 Coupe
Thumbs up It worked!!! THANKS
This method worked for me.
Thanks for the advice!
_
Old May 12, 2019 | 09:13 AM
Renhoek007's Avatar
2014 A207
I also deactivated the auto mirror folding on locking, for the same reason. I use the manual fold button if I wish to fold them. 😉
Old Jun 8, 2019 | 12:59 AM
Chevota's Avatar
E550 Coupe 2wd (2016)
I had mine stay stuck in the upwards position, and I'm the type that will not pay someone to fix what I can do so I went to work on figuring it out. I could hear the motor attempt to move it, but nothing happened. I figured it was
like how some things, like elect windows, get stuck because they drive full force until stopped, then can't overcome the stiction to free it and go back. So I tried hitting the wheel a little but I hate pounding on expensive things
unless I can see it can take it, so I took the cover off for a look-c. I pushed the lowering lever and could see the flex shaft move under the torque of the motor, but the screw wasn't budging. I simply turned the drive shaft at the
yellow arrow with a tiny 4" adjustable wrench, aka "All-Sixteenths" to unstick it and it was fine. It was just barely tighter than the motor could drive so I bet hitting the wheel harder may have done the trick. After looking at it I
believe hitting upwards on the wheel would be the trick in freeing it because it would reduce the tension causing the excess stiction. Or maybe just pushing up on it, for a moment, with your thighs would do the trick?
It hasn't done it since and has maybe 500 cycles on it so far, but if it happens again we'll see. I don't want to disable it because that would be admitting defeat, and imo taking a car to dealer is also admitting defeat
The assy in the pictures (I found online) is upside down btw. So fyi to anyone interested:
l:
