Disassembling a coupe seat back
I’m trying to fix a range of motion issue for my seat back. It’s a w212 2014 e350 coupe.
the coupes have a weird plastic seat back that i can’t remove and im afraid to break the plastic. Any ideas?
my ultimate goal is to get at the seat back tilt.
the passenger seat will tilt all the way forward to the point where it crushes you, but the driver seat only tilts forward to a certain point where your still kind of leaned back.
i hate being so far away from the steering wheel.
it doesnt exactly say how im supposed to release these clips.
can i get in there with a pry bar, and maybe apply lateral pressure?
anybody done this one yet?
so the seat back has a motor that has 4 poles in it, 2 of those poles are for the motor, and 2 are for a resolver.
when the motor turns a certain amount of revolutions, it hits that resolver limit and stops.
the passenger seat hits this limit very close to 90 degrees, like 91-93 degrees.
but my driver seat would only lean up about 60 degrees (maddening, i know)
so i took the frame apart, took and tested it it stopped at 60
took the angle limit sensor out, and insured it hadnt actually engaged at 60 degrees, it hadnt.
completely removed the angle limit sensor so it would stay at 45 degrees, and tried moving the seat. the seat stopped at 60 degrees like before with no sensor input from the limit switch.
took the hinge apart and inspected it for debris. nothing
took the motor out of the frame, and twisted the drive shaft manually. and the seat moved to 90 degrees.
put the seat back, plugged it back in and moved the motor up, and it stopped on its own.
took the motor gearbox apart and checked for debris in the gears, nothing.
pulled the gears out entirely, and ran the motor with no gears, just the naked worm, and it stopped.
ran it in the other direction, and it ran until i got bored.
ran it back, and it stopped.
next steps:
im going to mark the output shaft on the gearbox, and count revolutions to be sure my theory is correct, then
im gonna assemble the motor at its resolver set limit, into a seat set at 91-93 degrees like the passenger.
then assemble the seat in the reverse order.
all said and done, it looks like im going to come out on top.
but for F#ck Sake Hans, why so much engineering?
2 days on this god forsaken seat.
my wife misses me.
the seat motor will let you turn in infinite revolutions in the "seat back" direction, but only 4.25 turns in the seat forward direction.
i didnt see a "seat back" limiter switch either, only forward.
this might mean its possible to tilt your seat so far back, that it never goes "all the way" forward until you take it apart.
i have had this seat out once to detail under it. its not impossible that i leaned it back so far, but i doubt it.
i will keep assembling, and testing as i go to try and prevent this uncomfortable phenomenon again.
reassembled the motor and limiters, marked the shaft and counted revolutions. its 3.25 from lock to lock.
this means it wasnt me that effed up the seat, it was ****ing Hans at the factory.
fixed now. reassembling. i am the champion of the world.
and konigstiger saved me maybe a day and a half trying to figure out disassembly. thanks again man.
but yeah bro. My seat worked great when i got it back together
I thought there might have been a reset but back when I posted this thread I wasn’t able to find anything like it.
i had the car reupholstered about a year later, and the upholsterer broke the screws.
I got decent money for it and I enjoye the truck that I replaced it with so don’t cry for me☺️
