Occasional AC Fan Blower Not Blowing
Old Aug 26, 2022 | 10:53 AM
erich_aux's Avatar
2012 E350 Cab
2012 A207
Looking for ideas here…
Occasionally, the AC fan just does not blow at all. It appears the compressor is not an issue, just the fan.
I wonder if there is just a loose wire/connection somewhere?
Anyone have ideas on where to check?
Thank You in advance.
Old Aug 27, 2022 | 10:42 AM
konigstiger's Avatar
'71 Pinto
Check connections & f158 @ front pre-fuse box if fine, could be blower and/or regulator.
File Type: pdf
File Type: pdf
File Type: pdf
Old Aug 28, 2022 | 09:07 AM
erich_aux's Avatar
2012 E350 Cab
Thank you, Sir. Yet again.
Old Dec 30, 2022 | 04:18 PM
erich_aux's Avatar
2012 E350 Cab
Regulator
Konigstiger,
Apologies but night you have the uninstall/install instructions for the regulator?
Is that behind/under the glovebox as well? I think I see it in the upper left corner of the screenshot in the blower pdf you shared?
Interestingly, a friend also found these TSBs. However, I am pretty confident they will not fix my issue.
Thank You
Old Dec 30, 2022 | 04:55 PM
'71 Pinto
Bulletins are covered under MB factory & extended warranties. Replacement should have ESD by now regulator is plug & play located beside blower.
File Type: pdf
Old Dec 31, 2022 | 01:33 PM
erich_aux's Avatar
2012 E350 Cab
Thank you.
Old Sep 14, 2024 | 02:41 PM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
Ressurecting this tread. My blower stopped working. Before it stopped it was making little chirping noise which I know is a sign of the motor. 2 days ago it stopped working all together. So decided to replace both motor and regulator. The motor and regulator is the original part. Replaced both parts with original MB parts. Tested the old regulator (ohm) and the last pin was going in and out so was thinking that is the culprit. Tested the wires on the conncetors and everything was okay including the signal (also tested the voltage on the scanner of the fan speed and it is okay). Not sure what is wrong now. Pulled out these codes:
Before I bring it to the dealer to be gang raped any input from you guys?
Old Sep 15, 2024 | 07:23 PM
Fixed my issue. There was a disconnected cable behind the climate control. Most likely it dislocated itself.
