Wheel hop, which I now have for some reason
Meanwhile I thought I'd post to see if it's happened to anyone else, and hopefully a known and easy fix. I tried adjusting tire pressure up down, 26 to 36. Not that I really thought it would help but it was an easy experiment.
I can gas it in a turn and it spins both tires normally, but from a stop, or a roll if I'm going straight, it happens the moment they break free,
Can't tell if it's just one side or not, just that's violent! It even does it in the rain, which really surprised me.
2016 E550, M278, rear wheel drive. Not lowered or any parts swapped out, oem shocks, wheels etc. It has ~56k miles now
Continental Continental Extreme Contact Sport 265/35 18, which I've had for 5 months now.
I dunno, I never looked closely at my shocks so maybe they aren't, but they would have to fail in a very short time and cause wheel hop when they do, so I can't imagine.
If a linkage or bushing was bad I'd imagine I'd feel it, and probably see it in the alignment. It has the classic neg camber of bushings getting squished, but just the normal amount.
Thanks for the re Judge
\OT but is the rear diff in the E550 cab or coupe electronically controlled .?..if so then the control box, wiring etc may need investigating
It's supposed to be open diff, but who knows because 99.5% of the time it acts like a posi, but not that .5%. So kinda like that electric setup where it can turn off, but pretty sure that's an AMG only toy.
Either way, I don't see how posi or not would make a difference. I'm racking my brain and all I can think if is a broken sub-frame mount or bolt.
For now I adjusted my power so it won't break the tires free in a straight line, but not the fix I was looking for >: |
Other reasons for wheel hop are damaged half shafts or cvjoints in the half shaft. Bad struts loose suspension components, bad rear sway bar links or bushings
You may want to get it on a lift and check everything out with a large pry bar. While it is up there, if you have had the rear diff fluid checked or changed recently, check for correct fluid level and type
Then there's "950" AMG Sports Package, which I don't know what all includes but I seriously doubt a better diff. Plus 10K in upgrades per the sticker price, like option P02 and others that don't appear on the VIN search.
So to see if I could force a one-legger, I gassed it mid way into a left a turn to. I gave it less gas than usual to give the left wheel a better chance to break. Nope, they both broke free. Then mid-slide I let off just a bit to see if the right would catch first. Nope, they caught together. It's incredibly hard to control power with an elect throttle and wastegate. Lifting the pedal a mere 6% cost 140 ftlbs. Stupid electronic crap.
I also lightly power braked it at a light yesterday, spinning them to 12mph, but nothing. I did this exact same thing several times the previous week, including in the rain, and it hopped violently.
I was thinking about that .5% it seems to one leg, which was maybe three times ever. I've never been able to spin one wheel in a burnout, it's when one wheel catches mid-slide that makes me think that. Now that I think about it, it could've been ESP. When it catches mid-slide I'm too busy recovering from this disaster to notice an ESP light, at least I assume. So did it one-legged, or ESP and I didn't notice? Probably the latter now that I think about it.
Good luck.
Thanks for the input. All thought are welcome
