BBK options for 2012 E350 coupe
Old Jun 13, 2023 | 02:21 AM
Nbxjskamg's Avatar
E63amg
Are there any Mercedes factory Front and Rear BBK that bolts right up to a E350 coupe without needing custom bracket?
How about those fronts on E550 coupe?
I also read somewhere that W204 C63 Coupe BBK bolts right on to C207 E coupes?
Old Jun 17, 2023 | 08:27 AM
Evan Leeroy's Avatar
Mercedes c207
C207 brake upgrade
I just changed my front calipers yesterday what a difference!! I drive a Mercedes c207 and the w218 front Brembo calipers are direct bolt on. No need for any extra parts ..
Old Jul 4, 2023 | 04:39 AM
Nbxjskamg's Avatar
E63amg
Got any pics of your brakes?
Old Dec 5, 2023 | 02:09 AM
2014-E350 Coupe's Avatar
2014 E350 Coupe
I have a 2014 E350 Coupe and also needy to upgrade my Rotors,Calipers and Brakes. Anyone here able to help or chime in..?
Old Dec 5, 2023 | 12:33 PM
WRC-LVR's Avatar
2012 E350 Cabriolet now SOLD to my son
Try PowerStop they make a Z23 evolution kit f/r for the A207, and the coupe too. Mine was a drilled/slotted kit with Z23 pads. Zinc coated rotors too which look nice. Stops better then the OEM pads too.
When you do the fronts be sure to check the pistons for sticking, re mobilize as needed or replace the calipers
Here it is on Amazon for $519 USD :
Amazon Amazon
Old Dec 28, 2023 | 03:27 AM
2014 E350 Coupe
Here it is on Amazon for $519 USD : https://www.amazon.com/s?k=k7760&cri...f=nb_sb_noss_1
I don’t just want to swap rotors and brakes. I want the bigger rotors and 4 piston calibers. Perhaps E550 coupe sized rotors and caliber setup but upgraded version for the E550 Coupe model brake setup
Old Dec 28, 2023 | 10:22 AM
WRC-LVR's Avatar
Here directly from Powerstop for the E550 2014 are the bigger rotors and pads https://www.powerstop.com/products/
The 4 piston calipers and caliper brackets /hardware /sliding pins etc ... required ... you can get from MB for $$$$. Or you can search on Rockauto or FCPEuro to find them......
Old Dec 30, 2023 | 11:57 AM
2014 E350 Coupe
I will check with FCP Euro, will need to find their phone number to call up.
Old Jan 17, 2024 | 01:44 AM
EndlessAuto's Avatar
E coupe
CLS550 4 piston front caliper and CLK 360mm front rotor is direct fit to C207 fronts, without any brackets
Old Jan 17, 2024 | 04:45 AM
2014 E350 Coupe
Thanks for kind reply, is there a better rotor and pad upgrade. Don't want any rotor warping issues. What about better brake lines and fluid upgrade as well? Who sells these calipers at best price? Will C63 AMG Calipers fit directly as well from a 2010 C63 AMG?
