Smart Key not detected
Old Jul 30, 2025 | 02:50 PM
blawicki1's Avatar
2013 E350, 2020 SL450 R231
Has anyone had success in diagnosing and resolving the display message "Key Not Detected"? The message requires one to insert the physical key fob into the ignition slot to start the car. All other functions (lock, unlock) seem to work fine.. I've tried several resolutions. I've changed batteries, tried different Smart Keys, re-synced each key fob - all with no luck. Additionally this issue does not happen 100% of the time, I would estimate about half the time. I've tried to isolate different environment conditions - but there seems to be no consistent common thread to the problem. Car is a 2013 E350 Coupe. Any thoughts please..
Old Jul 30, 2025 | 03:17 PM
Davery's Avatar
2012 E550 Cabriolet 2011 VW Eos 1985 Pininfarina Spider
I don't have any suggestions, but hopefully this works out. It appears Mercedes no longer makes the Keyless Go FOBs for these cars.
Old Jul 31, 2025 | 10:32 AM
The_Judge's Avatar
2018 E400 Coupe
Several years ago a local repair shop lost our only FOB for my wife's 1999 C230. They initially acted like it was my problem, but after I threatened to sue them, they managed to find one that was made by some company other than MB. IIRC, they found it at a local key shop. In any event, they were able to configure it to work with her car. Wouldn't hurt to ask around.
Old Jul 31, 2025 | 11:19 AM
Davery's Avatar
The issue is getting a FOB that has Keyless Go. FOBS are still available for cars without Keyless Go.
Old Aug 1, 2025 | 12:14 PM
blawicki1's Avatar
Given the fact that I've tried both smart keys and neither work 100% of the time - I am skeptical that the fob is the issue.
Old Aug 2, 2025 | 11:37 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
UNSTABLE KEYLESS MODULE
Your issue is likely with the KeylessGo module itself or less likely, the Ignition slot module. They both work together to authorize the FSB4 key.
Consider these steps:
-1- Use a scanner to survey and clear all unstable modules gone wild, a 5mn procedure.
-2- Reboot chassis to sanitize silently unstable CAN module such as sleepless CGW.
The keyfob could be bad, but unlikely.
When batteries are discharged this helps make long-distance rear modules more unstable (KeykessG)... float-charge up your batteries with a CTEK or NOCO.
So it's not one item you need to deal with but an array of marginal conditions that need to be sanitized + prevented.
+++ COIN CELL...
Not to overlook the obvious: the key fob battery can get drained and is easily replaced.
Old Aug 2, 2025 | 02:35 PM
blawicki1's Avatar
Very interesting and thanks much. I am passing this along to my mechanic - who will be doing the investigation / diagnoses next week..
Old Aug 3, 2025 | 10:37 AM
RealDonn's Avatar
2011 E550 Cabriolet
It would help a lot of us if you could find where your local repair shop got that fob.
Old Aug 3, 2025 | 02:00 PM
blawicki1's Avatar
Both of the fobs I referenced are original to the car.
Old Aug 3, 2025 | 03:43 PM
RealDonn's Avatar
2011 E550 Cabriolet
To The_Judge - It would help a lot of us if you could find where your local repair shop got that fob.
Old Aug 4, 2025 | 10:43 AM
The_Judge's Avatar
2018 E400 Coupe
RealDonn — I have no idea, and although that location is still a shop, it's under a different name, different owner, different crew, which is hardly surprising. I mean, how can a mechanic work on a car, moving it in and out of the garage, move it to the parking lot, and then lose the key (or FOB in this case)? Morons rarely stay in business for long (can't say the same about politicians, unfortunately).
BTW, the replacement FOB looked significantly different from the original MB fob — it was black, for one thing, and a bit larger — but it worked.
