E-Class Coupe (C238) & Cabrio (A238) 2017 - E200, E220, E300, E350, E400, E450 [Coupes &Cabriolets]
E450 coupe (2021)
Old Nov 13, 2021 | 03:48 PM
cpasam's Avatar
E450C4 2021
E450 coupe (2021)
How do I disable ACTIVE SPEED LIMIT ASSIST?
This feature can be very dangerous when the vehicle is slowed abruptly.
Old Nov 13, 2021 | 05:30 PM
Elvisfan0108's Avatar
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
As has been mentioned before, and is also in the manual.
Multimedia system:
4 Vehicle 5 k Assistance 5 Traffic Sign Assist
Activating or deactivating automatic adop‐ tion of speed limits
# Select Limit Adoption.
# Activate O or deactivate a the function. The speed limits detected by Traffic Sign Assist are automatically adopted by Active Distance Assist DISTRONIC.
Old Nov 13, 2021 | 05:36 PM
W205C43PFL's Avatar
It might be in MBUX> Assistance > Traffic Sign Assist (Three options: Visual & Audible, Visual or Off) Once you set it off, it should no longer change the speed you set for distronic anymore when the camera reads a different posted speed limit.
Old Nov 13, 2021 | 05:50 PM
cpasam's Avatar
E450C4 2021
Thank you.
I believe I have done that already, but will try it again next time I’m in the car. That would be great if I can turn it off.
For example, school zone slow downs on weekends or holidays, or erroneous readings on interstates can be prevented by turning this off.
Old Nov 13, 2021 | 05:55 PM
W205C43PFL's Avatar
You're welcome, forum member @Elvisfan0108's post is more detailed so hopefully it helps you more. I didn't realize someone else already answered, sorry. I should had refreshed the page.
As for why it might not be working, it is possible that it defaults back to on (like lane keep assist or something else can't remember, every time you start the car just like autostart stop)
Not quite sure if this matters, but try setting it while having distronic on but foot on the brake (and that the surrounding environment is safe) ie. so the car doesn't start moving to follow the car in front while you are setting it)
Old Nov 13, 2021 | 06:40 PM
It is in traffic sign assist. However, you stated the wrong option. All that is is a warning of a change. LIMIT ADOPTION is the option you want. I googled the manual and found it in about 5 minutes. I have a C series. Almost the same.
Old Nov 13, 2021 | 07:08 PM
W205C43PFL's Avatar
Make sense, thanks for the correction.
Old Nov 14, 2021 | 11:17 AM
cpasam's Avatar
E450C4 2021
We’ll see
Sometimes each group has it’s own characteristics.
