E-Class Coupe (C238) & Cabrio (A238) 2017 - E200, E220, E300, E350, E400, E450 [Coupes &Cabriolets]
The most annoying rattle in the world
Old Jan 30, 2024 | 05:02 PM
Louis hughes's Avatar
Mercedes e class A238
Hello
please please help…. I’ve inherited a hideous rattle coming from the rear passenger side on the parcel shelf on my A238. Literally any uneven road surface (from Essex so that means everywhere 🤦🏼‍♂️) is when it’s worse.
I’ve been in the back and can’t pin point exactly where it is on that area.
there is next to no movement on the joins. I’ve had the roof partially open to look underneath and again seems to be nothing loose or out of place.
hoping for some help before I drive the thing off a cliff whilst I jump out 😂😂😂😂😂😂😂😂 it’s that annoying 😂
Old Jan 31, 2024 | 09:25 AM
wasmans's Avatar
E 300
Are you sure the rear seats are locked in place? I once pulled the lever in the trunk and caused one of the seats to be slightly loose. That may be worth checking.
Old Jan 31, 2024 | 10:09 AM
yes bud I’ve pulled them both and shut them up with force then tryd to pull them and they don’t come forward.
it’s coming from the partial shelf area behind the head rest only on the passenger side
Old Jan 31, 2024 | 12:03 PM
The_Judge's Avatar
2018 E400 Coupe
Perhaps a loose speaker???
Old Jan 31, 2024 | 12:10 PM
this could be the case and has passed my mind.
do you know how I could check this or how to get in to look
Old Jan 31, 2024 | 12:18 PM
The_Judge's Avatar
2018 E400 Coupe
Originally Posted by Louis hughes
. . . do you know how I could check this or how to get in to look
Not a clue, found nothing in the manual.Maybe through the trunk?
Old Mar 2, 2024 | 12:28 PM
Atilio's Avatar
2018 E400 4matic coupe
Hello
I have been having the same issue..its so annoying
Old Apr 1, 2024 | 08:34 PM
DaThresh's Avatar
2016 Mercedes E250 Bluetec Designo
Can you provide a video of this noise?
Old Apr 2, 2024 | 09:24 AM
Grant_J's Avatar
'18 E400 Cab
I just reread the thread and remembered my A238 does something similar but the issue is the seat belt. It doesn't have enough tension on it so it rattles sometimes, especially with the top down. I pull the rear seat forward and stick the buckle in the trunk to hold it still. Without a video I can't say this is your problem, but worth a look.
Old Apr 2, 2024 | 11:59 AM
wasmans's Avatar
E 300
I once had a noise that turned out to be coming from the loose 5-point harness on a child car seat in the back. Had to remember to click all ends in every time I drove.
Old Jun 20, 2024 | 12:39 PM
lbowersaz's Avatar
2022 AMG E53
Louis - did you ever figure this out?
Old Jan 27, 2025 | 05:32 AM
Harritso's Avatar
C238 E220d 4Matic Coupé - W176 A200d - W201 190E 1.8 Aut.
Did any of you find the cause of the rattling noice? I have the same issue with my C238 - E220d 4Matic 2017
Old Jan 28, 2025 | 05:49 AM
yes mate found it
it was the parcel shelf where it comes down for the roof
I used some foam tape (draught tape 2mm/3mm) see attached under the parcel shelf along the edge and it stopped straight away.
pretty poor from Mercedes that it’s does this
Old Jan 28, 2025 | 05:55 AM
Harritso's Avatar
Thank you very much @Louis. Highly appreciated. I know I'm asking a lot, but can you perhaps share a photo from the car, of the exact location where your problem was? Pardon me asking, but I'm no expert in trouble shooting, and appreciate all the help I can get
Old Jan 28, 2025 | 10:17 AM
The_Judge's Avatar
2018 E400 Coupe
Agreed. I have no idea what you mean by the phrase "the parcel shelf where it comes down for the roof."
Old Jan 30, 2025 | 08:05 PM
superpop's Avatar
2019 S63 4Matic+, 2018 E400 Cabrio, wardens car.
I had the same issue with my wifes car. The foam tape is a definite fix. You have to apply it on the front edge where the parcel shelf comes down and meets with the area just behind the rear seats. I raised the roof until the shelf with the two speakers was raised up and just ran the tape all along the joint where the front of the shelf meets the car when it lowers. Car is silent now.
Old Sep 21, 2025 | 05:14 PM
aceboogie2025's Avatar
2019 Mercedes Benz E Class Convertible Rattle
Hi, new to the forum, having the same issue with my vehicle, any chance of uploading a picture of exactly where the foam tape would need to be attatched? please get back to me asap would be much appreciated, thanks.
Old Sep 21, 2025 | 05:15 PM
Old Sep 21, 2025 | 05:17 PM
Old Sep 21, 2025 | 05:19 PM
[QUOTE=superpop;9105517]I had the same issue with my wifes car. The foam tape is a definite fix. You have to apply it on the front edge where the parcel shelf comes down and meets with the area just behind the rear seats. I raised the roof until the shelf with the two speakers was raised up and just ran the tape all along the joint where the front of the shelf meets the car when it lowers. Car is silent now.
QUOTE]
QUOTE=aceboogie2025]Hi, new to the forum, having the same issue with my vehicle, any chance of uploading a picture of exactly where the foam tape would need to be attatched? please get back to me asap would be much appreciated, thanks
QUOTE]
Old Sep 21, 2025 | 05:22 PM
Any chance of uploading a picture of exactly where the foam tape would need to be attached?
Old Sep 21, 2025 | 06:33 PM
superpop's Avatar
Here are a few pics of the area. You can see where I put the tape in the second pic.
