E-Class (W123) 1976-1986: 240D, 280E, 300D, 300TD, 300CD
Heated seats in 300D
Old Oct 5, 2007 | 11:26 PM
n23ova's Avatar
'83 300D turbo; '79 300SD turbo
I'm wondering... It seems that some of these cars had heated seats. Unfortunately mine does not.
Was there a "cold weather package" that was optional with these cars? Mine is from 1983 and has always been owned in the state I live in.
Old Oct 6, 2007 | 02:59 AM
240D 3.0T's Avatar
1982 300D VNT, 1980 240D 3.0T, 1982 300TD
Heated seats were just another option, although a rare one.
Old Oct 9, 2007 | 08:58 PM
lkchris's Avatar
'10 CL550, '12 GL550
No heated seats for W123 anywhere in EPC.
Must go to aftermarket.
Old Jan 4, 2008 | 08:48 PM
cheapold280CE's Avatar
1978 280CE
I have heated seat in my car it's a euro 1978 280CE Haven't tested them as I am busy trying to get it running after it's 15 year sleep in a barn. I was surprise that they even had them in 1978.
Old Jan 4, 2008 | 09:53 PM
Untertürkheim's Avatar
That must be an error, heated seats were a factory option (as were orthopedic seats) in the C/W/T 123.
Old Jan 13, 2008 | 06:12 AM
Lurking thanks's Avatar
The oe heating pads are on ebay atleast once a year but people want way to much for them, i'd just get one that plugs into the ciggerette lighter and take it apart, then slip the pads under the seat surface and permenantly wire it in, some of them have digital controls that would be better than oe anyway.
Mine has a factory heated drivers seat there is only two setting "way to hot" and off lol, the w126 heated seats, I think, were the first to have timers so they heat up the seat then turn off automatically.
Old Jan 30, 2008 | 09:19 PM
v8plus4's Avatar
2024 AMG G63, 2023 Bentley GTC Speed
Front heated seats were optional on US 123's for around 3 or 4 hundred dollars. They were 2-stage like the 126 and later models. The switches were located on the lower center console between the front window switches.
Old Feb 1, 2008 | 06:46 PM
1978 280CE
here's link to w123 heated seats:
http://pauldrayton.com/uploadfiles/m...sis/82-800.pdf
http://pauldrayton.com/uploadfiles/m...sis/82-810.pdf
http://pauldrayton.com/uploadfiles/m...sis/82-820.pdf
http://pauldrayton.com/uploadfiles/m...sis/82-830.pdf
This is the type I have on my 1978 EURO which BTW still work and they work wonderfully. I never had heated seats before and OMG they are so warm I love them.
I just bought Reggie Jackson's old sheep skin covers. They are really nice seat covers I assume the heat will pass throught the sheepskin.
Is it O.K. to used heat and Sheepskin??
Old Apr 15, 2008 | 08:03 AM
BF_JC230's Avatar
2005 w203 C230
The "Loaded" w123...Gotta have a manual!
Jake
Old May 6, 2008 | 10:29 PM
thebenzbar's Avatar
MB
Yes, heated seats were an option... very rare though for the later w123 models.
Old May 21, 2008 | 03:43 AM
My drivers seat is heated, it gets HOOOT!, there is a switch in the upper corner near the shift lever, they changed the button style to the one above atleast after 1980, on a 1985 500sel it's a timed button that will turn off the heat after a few minutes. Is it like that on a w123?
edit: mine are like cheapold280CE's not the newer ones.
Old May 26, 2008 | 06:15 PM
1978 280CE
On my heated seats If you push the toggle button forward seats get really hot fast, I don't know it they will turn off buy themselves after time or not , as it gets to hot and I switch it to single dot position.
But the manual mentions two versions and only on first version does it say don't leave it on too long in double dot position. And it calls the single dot a continous position. So I figure in the second version a timer is used and seats cut off if left in double dot position.
I mostly just use the single dot position and it does stay on.
Old May 28, 2008 | 02:54 AM
Yeah those are the older ones and not timed, the newer ones may be on a timer (they are in the 1985 w126 500sel which have the same buttons)
