Need Help Please Read... 300e 1987
Check that you don't have a blown head gasket: is the water clear (no oil)?
How long at idle before the head heats up and to what temp? What prompted the water pump change?
The A/C must be switched on and engine hot to run the aux fan.
The auxilary fan has a thermoswitch on the head the diameter of a quarter under the air cleaner. Pull off the double lead and jump them with some wire (with the engine running or battery on) This should run the fan if it's working properly.
that will tell you for sure if it runs or not, it will keep running even if the engine is not on...
PS: I'm from beantown too
BTW, you can tell if the aux fan is running by looking at it turn! Yes it must be warmed up enough for the thermoswitch to turn it on.
You should also inspect the belt driven fan since it is a fluid clutch that can loose it's grab. In other words if it is not working properly, it won't have much resistance when you try to turn it with your hand (while the engine is off)
