Possible Modifications to 1991 300ce?
Engine is still shot, car still pulls 16s 0-60 runs, but I'll manage. I think.
I'm excited to see what I can pull with my front/rear sways, lowering, H&R Sport + Koni Yellow (4/5 stiffness), slotted/cross-drilled rotors, and grippy pads.
Here is one of my final "for the lulz" mods. Its called EZ-lip. It is a foam rubber lip with 3M body tape. 35$ shipped, goes on fast/easy, and IMO looks pretty great considering.
I could have done a better job on the install, but it literally took me about 2 minutes to do so I get what I put into it I suppose. I'm too impatient
The meet went great! The suspension mods were.... amazing, absolutely amazing. Turns out my summer wheel set is actually a set of bald M+S tires soo... grip wasn't fantastic. That being said, I still pulled some okay laps. Adjusted, I was second from last in the Novice class haha. In terms of raw times, I know I beat a C5 corvette and the Skyline GTR a few times. They're apparently very... slow about posting results, so who knows when I'll have them and be able to post videos.
If I can ever fix the SLOW and find some grippy tires, I might actually be a contender haha.
Here is a quick/dirty cut of my 7/7 run. Not sure what the time was, they've still not posted them. Proper ones will be up once I get my times.
Swapped my 008-545-73-32 ECM/ECU for a 011-545-43-32[00] ECM/ECU.
Experienced exactly 0 difference in the car. Guess the ECM/ECU isn't at fault here for my car performance issues.
It was vehicular homicide that's what it was !
You need a transplant like SMAutoworks - M119 4.2l V8.
Tempting, but that is a large/heavy engine to stuff up front. I'd rather keep the weight balance a bit more neutral.
http://w124-zone.com/downloads/MB%20...04/05-2230.pdf
Went to the track this morning and had some fun. My housemate is in front of me in the 2007 CLS63
I would like a more expert opinion about cams setup on M104 and how it affects performance, might be the clue to your problems.
I'll try and get a good video of it soon.
They are Lift stickers for the frame jack-point covers. Fortunately, they also correspond to where the frame jack pads (the rubber ones) are under the frame rails. So, either way, its a win as it points out where to lift the car from.
I've had shops be confused about how to lift my car up
Chlippo, here is a video containing 0-60 run, general driving, and a 0-40 run from a stop with a corner (car sort of stalls).
My car now has the latest:
MAS: 008-545-85-32
ECM: 011-545-43-32[00]
My car has an ancient EZL:
010-545-95-32[09]
The latest EZL for my car is:
016-545-04-32
I don't think my cams are even advancing at all! I replaced the cam solenoid about 3 years ago, so I doubt its gone bad again.
I honestly really think my car is on full manual control, no electronic ignition control.
Edit:
When you pull the vacuum line out of the EZL with the car running, should you note a change in idle sound or anything else like that?
Uploaded the videos of the SCCA meet from a few weeks back. Enjoy!
The suspension mods were so so worth it. Now if only it had a functional engine and actual tires, not bald M+S tires...
Just be sure he really knows what he is doing if he does, we dont want to eliminate the cams before knowing 100% its not their fault
Check this link, might help you eliminate/check the cams
http://www.peachparts.com/shopforum/...procedure.html
