common w124 Rattle?
Old Sep 29, 2006 | 12:42 PM
myfirstbenz's Avatar
95 E320, 19 Ram 1500 Hemi, 21 GLS 580(wife)
common w124 Rattle?
So I have noticed lately that when driving over cracks in the road or the like,that there is a faint rattle comming from either under the car or the rear of the car. It sounds like a muted tamborine or a baby rattle. I have searched the forum and some have said to check the heat shield which I have done, but Some say that the Cat going bad can do this noise as well... how do I get that tested. It looks fine and the car performs fine, so I really doubt it is the cat. Are there any other suspension members that have been known to cause such a sound? I noticed driving my buddies 300E that his does the same sound.
Old Sep 29, 2006 | 01:11 PM
shadowgriffen's Avatar
is a German Tank
hmmm...the only rattle I hear is my passanger side shock, curtesy of Boston roads.
I'll check into this.
Old Sep 29, 2006 | 01:42 PM
Falconeer's Avatar
Mercedes Benz 300E, 1991
Mine Too!
Old Sep 29, 2006 | 03:12 PM
Barrington1's Avatar
the worst rattle i have is kind of a baby rattle tamborine noise that i hear going over bumps that is around the passenger side seat..really pisses me off.
Old Sep 29, 2006 | 04:32 PM
mgw_300e's Avatar
Dora the Explorer
things that will cause that kind of noise:
  • worn suspension bushings, especially the strut bushing at the top
  • loose heat shields
  • loose exhaust parts
  • anything loose that has a washer would probably make the "baby tambourine" noise
The easiest way to hear your car while you're driving is to drive parallel to a wall or other solid object that will echo the sound back to you.
You could also go under your car with a rubber mallet and start tapping on things until you recreate the sound (probably won't work if the problem is suspension parts - but who knows)
Old Sep 29, 2006 | 07:01 PM
bjay51d's Avatar
1989300CE(sold),1996Accord,02CBR954
I'm so pissed I was going to put the car in the shop for frt struts tomorrow.I was expecting my stut mounts today and I missed the ups man Im at my wits end with that damn rattle.
Old Sep 29, 2006 | 07:47 PM
neanderthal's Avatar
these cars are very well put together.
if you just around the car and tighten every screw, nut and bolt you will find that will probably kill most rattles. of course some are going to be hard to get to, but do what you can.
the most annoying rattle in my is the cds in my cd case.
Old Sep 29, 2006 | 07:51 PM
mgw_300e's Avatar
Dora the Explorer
Originally Posted by neanderthal
these cars are very well put together...
You said it.
BTW, how ya healing from your injuries?
Old Sep 30, 2006 | 02:02 PM
slowly
thanks for inquiring
i have been back at work for about the last two weeks. im getting better and stronger everyday. sneezing still feels like im getting chopped with a sharp axe, and i tend to sneeze in fits of three or four, so im tryin to stay away from dusty environments.
i went to rugby practise on thursday for the first time in about a month and some. i was able to run, but had lost a lot of fitness. as the evening went on and i got tired, the heavy breathing started to hurt. yup, heavy breathing was hurting.
im gettin better though.
word of advise for all. stay young (you recover quicker) and dont continue play rugby as you get older. even if you started playing 22 years ago like i did. its a very physical sport. it doesnt need to be said that you can get hurt.
that said, i should be in good enough shape to play when the season starts in january.
Old Sep 30, 2006 | 03:01 PM
UPDATE!!!
So I went out for a drive yesterday afternoon up to the mountains outside of town, and on this paved single lane forest road there were 3 cattle guards in the road (apprx 8 2.5" metal pipes layed perpendicular to the road such that cattle cant walk out of a fenced area). When I drove over these guards they of course vibrated my car for a brief second until I passed over them. Now, my rattle is gone if not 90% better!
So I guess if the Italian tune up is for engines, we could call this a cowboy suspension tune up/rattle eliminator?
Old Sep 30, 2006 | 03:36 PM
it only means that something was jiggled into its proper place for a time. it will come back if you go over some other bumps.
of if you reverse your route and go over the cattle guards the other way
Old Oct 10, 2006 | 09:37 PM
bjay51d's Avatar
I replaced the front struts like my ripoff artist indie told me .And the rattled seemed like it got worst.So I jumped under the car to see what I could.Nothing seems that worn that It would be making noise.So I grabbed a couple of sockets and went to work.I tightened everybolt I could reach.To my surprise the rattle was gone.
Old Oct 10, 2006 | 10:03 PM
Ain't that satisfying?!
Old Oct 10, 2006 | 10:21 PM
bjay51d's Avatar
I just wish I hadnt put any faith in that mechanic.Id have a few hundred more dollars
