Transmission behaving strangely...
Anyone have a similar prob?
In many ways it helped my car, and in many ways I feel I ruined it. Although it no longer leaks trans oil, the tranny now shifts stronger, although not better, and it has somewhat ruined that beautiful-smooth like butter shifting it had before.
whatever you do just take it to a shop and see what they say, leave the trans to the pros.
here is a quick tip -
* check your trans oil level (could very well be you have low fluid, and therefore your tranny has the hickups.
good luck.
Do you hear any kind of random popping under the car when you have the accelerator all the way down and it is not giving you the power it should?
I also checked the tranny fluid level afterwards, and it was low (got some more).
Well, I guess there IS a remote chance that it could because when you move the car from park to drive, the RPMs will drop from the load of the transmission. So if the transmission wasn't engaging, your RPMs would remain uneffected. This really doesn't sound like what you are describing, because transmissions cannot make your engine surge. It would either make them drop, or leave them unchanged if it wasn't engaging.
Common causes for your symptoms are: 02 sensor, ovp relay, wires, plugs, distributor cap, rotor, fuel distributor, EHA adjustment, injectors, sticky idle control valve, bad fuel pump relay (or MAS control unit if you're unlucky enough to have a model with one). Put some Techron injector cleaner in your next new tank of gas, and take it out for a hard drive. High RPMs and high heat. Give it an old italian tune up. See if that helps it.
I have been chasing a very similar problem in my car pretty much for the entire 3 years I've owned it, to no avail. Maybe you'll be luckier than I.
This from a member on benzworld -
"On Sunday I changed out the glow plugs in my '84 300SD and on Monday, the throttle linkage started sticking. Right now it doesn't release very well and I don't like it. I'm pretty sure that I must have done something when changing the glow plugs, but I can't see anything obvious.
The last time I had a linkage problem it was very hard to push the accelerator. I cleaned and grease a few of the linkage connections on top of and around the engine and it worked beautifully. Now, it just doesn't seem to want to release. I thought it was the slotted "cam-follower" arrangement on top of the calve cover, but greasing that did nothing.
Doesn't look like I bend anything.
Anyone have any ideas?"
I sprayed some WD-40 on the linkeage, but listen to my buddy Matt Witter (MG_300), he has the correct info on proper lubrication.
The assh*le who at first ignored me then finally talked to me...took one look at the car, and said it's not worth it to fix...I should trade it in for a newer model, and I'd probably get $200.00 trade in value. WTF?!
I'm not a violent person--but I felt like punching the motherf*cker.
how old are you, if you dont mind?
So you mean to tell me that 20 years from now a current w221 S-class owner will be treated the same? I think not...
I did, however, find this wonderful mechanic who trained at Mercedes Benz, and I went to his shop, and was completely satisfied. Trouble is, he's one of two mechanics, their shop is completely full, so they have a 24+ hr turnaround time...
Goodl uck!
I have found that the best guys to take it too are knowledgeable former dealership technicians that have their own private shop, the prices are much lower, they usually know the cars inside out and most of the time can diagnose a problem without even opening the hood
. I've never changed it...I don't know if the old owners did, either...
