Please help me identify these wires
BTW i tried several times to resize the pictures. It WOULD not WORK! Sorry!
first pic shows the power plug. It is numbered 1 - 4
pin 1 = brown = ground
pin 2 = black with yellow stripe = +12v switched
pin 3 = grey w/blue stripe = illumination
pin 4 = red = +12v constant
2 black and white thicker gauge wires going into the front of that plug are not original as you might have guessed by the way the wire ends are exposed...I would trace those 2 wires and see where they lead.
These are the plugs for the rear speakers...the original becker in your car was a 2 channel stereo and the signal was split at the factory fader that is mounted on your console. If these were disconnected and the rear speakers work then it was already bypassed.
1992 MERCEDES 300CE
