ABS issues
Old Feb 6, 2009 | 10:57 PM
jwframe's Avatar
1986 300e w124
Exclamation ABS issues
I have a 86 300e. At every stop the abs was coming on which actually seemed to reduce my stopping distance on dry pavement. I had a mb mechanic look at it and he cleaned the abs sensors (I assume the ones at each wheel??) This worked well for about a week and then the problem started over again. My method of fixing the problem was to unscrew the abs box in the engine compartment and remove the relay. This made the abs light stay on permanently and fixed the problem of unwanted abs. Any thoughts on actually fixing the problem instead of bypassing it? I search the w124 forum but didn't find much about this.
Old Feb 15, 2009 | 08:03 PM
landspeed124's Avatar
1987 260E
Bump. I'm interested in the answer to this as I have the exact same problem.
Old Feb 15, 2009 | 11:20 PM
berti_00's Avatar
2016 Cls63s AMG
hahaah i am havin that same sh!it too WTF.... when the abs light is on the car breaks fine no problem but when i come to a stop and the abs light is NOT on the car hesitates to stop right away i mean it stops but makes this grinding noise which i assume is abs stuff?
anyone
Old Feb 16, 2009 | 05:52 PM
viperuk1's Avatar
Mercedes 300CE Coupe
I had a problem when braking at really low speeds the ABS would engage. Really annoying bit of a grinding sound, i believe it was on of the ABS rings had split or some thing like that an at low speeds the sensor thought the wheels were stopped (locked) so engaged the ABS.
We had some bad snow an ice an while going down a hill i had the ABS engaged for a good 10 20 seconds an now it seems to have stopped. im going to get it checked out soon though so will hopefullly have some answers.
Old Feb 16, 2009 | 07:48 PM
berti_00's Avatar
2016 Cls63s AMG
yah exacly same here... plzz do let us know what it could be the problem would love to know...
i went ahead and bought whole ABS unit but never got around to changing it soo
Old Feb 17, 2009 | 03:42 AM
viperuk1's Avatar
i think i spoke to soon. was driving this morning an it happend again!!!
will get it checked soon an let you know.
Old Feb 17, 2009 | 07:49 AM
TheGerman's Avatar
W201, W124, W126, . . .
Check the wheel bearing backlash, first.
Old Feb 17, 2009 | 03:45 PM
YNVDIZW124's Avatar
lots of cars
Bleed the brakes correctly, it should go away. I fixed this a year a go but i forgot how to fix it! I still have a replacement sensor somewhere...
It's kinda scary when you can't stop and it pushes the pedal back at you.
Old Feb 17, 2009 | 04:55 PM
viperuk1's Avatar
mines not that bad yet just kind of pops on for a brief second, booked in for monday so might have some answers then.
Old Feb 17, 2009 | 08:33 PM
berti_00's Avatar
2016 Cls63s AMG
my breaks are bled in correctly? but still dono what
Old Jun 7, 2009 | 03:36 PM
Kourier's Avatar
Here is a late reply..
I bought a car with ABS warning light on, checked all sensors whoch seemed to be reading ok. Its an '87 so its more than 20 yrs old at this point..
I dont have a diagnostic tool so I plugged the sensors one at a time into an audio amplifier much like you would a microphone (abs uses magnetic pickups, small signals like a microphone) and spun the wheels and I could hear it working. (sensors $170+ each)
Since that seemed fine, it stands to reason every sensor has a computer so I reseated all the black boxes behind the bettery (unplug, clean and put back in) and my problem went away.
I even found a slippery street and jammed on the brakes to 'test' the abs and it worked.
hope this helps...
Old Jun 7, 2009 | 05:48 PM
ps2cho's Avatar
E
^ A bad OVP will throw the ABS light on even if the ABS works fine. Keep this in mind if it returns again.
I had the same problem on my both W124s when I bought them.
Old Jun 8, 2009 | 11:12 PM
morris374's Avatar
1991 420SEL & 300E, 2003 BMW X5, 2001 740iL all on DUBS
hope this helps...
where are the ABS sensors located?
Old Jun 11, 2009 | 12:44 AM
1987 260E
Two in the front in each front wheel hub and one in the rear diff.
Old Jul 8, 2009 | 06:16 PM
124-Fan's Avatar
Mercedes Benz
The actual answer to this lies in the toothed abs pickup ring at either of the front wheels. Its either damaged or there is rust inbetween the teeth, fooling the abs sensor.
Fixed excactly this problem the other day by prying out old rust and dirt from between the teeth with a small screwdriver. Then sprayed it with WD40 and brushed the teeth with a wire brush. - Like new afterwards..
Cheers,
