Just bought an 87 260E
Once you get the cluster out(had to go through the paneling to push mine out)All i had to do was push a gear back into place, some locktite in the right place and hopefully it will work for quite awhile.
W123 Odo Repair
That guide pretty much covers the W124's odometer problem. But being a W124, the odometer's housing is more complex, or at least more constricting, and it is difficult to properly place a drop of adhesive to that last metal gear.
But, to just get the odometer running again, chances are all you have to do is push the pin back through that last gear, not sure how long it will stay there though.
W123 Odo Repair
I also noticed my dome lights stay on after the car has been locked and they don't turn off....
And lastly (for interior questions)...the console lights near the shifter don't work. The windows (well one...) work so there must be power. Is there a bulb or a fuse for it? Any ideas?
What position is the switch on? There is a position that turns it on when you open the doors.
There's a small bulb on the shifter console just unplug it and replace it.
Furthest forward...same as my TE. I've tried all the positions though just in case.
Once I get the new ignition wires and put my TE's old rotor + cap + o2 sensor on the 260E I'm gonna talk to the guy at the smog station to just run it to see if I will pass and check to see where I stand. They didn't make any difference when I bought new ones on my TE...so I figure no point spending $180 quite yet. Free to test right
Lookin much better with the black bumper now. Still need to find a good one at the junkyard too as up close this one has scuffs and dents all over it.
So since you guys are all in socal, anyone willing to help a brotha out with some little things on my wagon? I really want to try changing the spark plugs and doing a DIY tuneup if possible. Not sure if that is something I could do myself or not.
I live about 10 minutes from one of those Ecology places so I might try it out and see if they have an A/c control unit. This coming weekend is 50% off, anyone wanna go with?
Get yourself a Haynes manual first!
That...or find everything you need here:
http://www.ps2cho.net/downloads/MB%20CD/W124/Main.html
I have high HC's...that's why.
New ignition wires in...Runs a tad better...
See that oil leak going down towards the front? Is that the timing cover gasket gone?
Also...I noticed that when the car is cold, at first start up, the rpm's used to shoot up 4-5k (rev counter only, not the actual engine)....but it didn't do it...so that's one thing solved
New idle air hoses on too.
Going to put the O2 sensor on this weekend, fiddle with the mixture one last time and take her back to the smog station to see where I am at. Gonna try and ask if I can just have it checked to see if it will pass or fail first before they do the "real thing"...
Fiddled with the mixture and took her back to the smog station.
Still failed, but I made huge progress!
Why did my %O2 increase? My NO decreased dramatically!. So all that remains is the HC. HC = ignition related? Or can it be Cat related?
Looks like for smog we need to check the EHA, OVP, o2 sensor, and ICV.
BTW, I would go again but first fill up with 91 octane and add two bottles of ISO-HEET. They sell it at pep boys for like a dollar. Did you change your o2 sensor? Also, look at your fuel mixture or %CO2. You are running a little lean it should be 14.7-9.
Why does your report look different than mine?
I did not change the O2 sensor yet as I was hoping it would pass due to the EHA fix.
I will take your advice for next time and fill up with 91 and the ISO-HEET. I was going to swap the O2 sensor, but I brought the wrong wrench (thought it was 18, but it looks like it is 20mm. Car is banned from my apartment right now so I gotta drive to a friends house to work on it.
I think it looks different because I have the before paper behind the after. Two separate papers if you look. I just matched them up so you could see the improvement.
I am also considering getting a new engine temp sensor as its only that and the o2 sensor left that affects the mixture. It looks a little shabby that's why...The only thing I have actually bought for this car so far is the ignition leads. Everything else I have swapped with parts from my TE's box
Well, I would do the O2 because it looks like the EHA is back on track and maybe that's making the fuel mixture lean. After every Idle mixture adjustment you need to drive it around so the computer can re adjust the mixture. You need to drive for at least 30 min and get the car really warm. Do not turn it off when you get to the smog place but i would make an appointment first.
What I meant was that my info is all on one paper..
Just got back swapping the O2 sensor out. I used my TE's old one again because I swapped it and made no difference during my rough idle hunt...so for now it will suffice on the 260E. Visually it looked 5x better than the one I pulled out. It seems to be a little smoother. Going to get the oil changed and make sure the tires are inflated evenly and go for the test once more. I was so close so I think I will get it this time. The oil probably has not been changed in 2-3 years so I read that it can cause vapors that increase HC. Only reason I have not gotten the oil changed is because the car is not street legal and the tags are expired for over 2 years...so I have been very careful.
Well, you can register the car without the smog and just get a permit number for that month. You shouldn't have done the smog with oil that is probably 2 years old. Every time i get a mustang I run three oil changes with cheap oil to clean out the sludge because it's like breaking in the engine all over again. Once you get it smoged you'll be set and then you can start modding the exterior and interior. I wish there was a good w124/201 car club in cali that actually met and shared mods. I remember the one we tried to start but umm didn't work out...one2four...lmao.. I know everyone goes to TJs in irvine but it's mostly newer benzes..
Who's going to the junk yard tomorrow?
How do you set the mixture on your 300E? Can you tell me the exact steps you take? I want to make sure I am doing it correctly on the 260E because it does not have the diagnostic controller like my 88 does.
Also you said that I am running a little lean due to CO2 levels. If I adjust the mixture and make it richer...then won't the HC increase?
The way i do it is to just disconnect the idle control valve while the engine is running and lean it to where engine is almost stalling. Connect the idle control valve and turn the mixture screw clockwise a little to enrich the mixture. You'll notice it'll start to rev up a little after each time you move it, leave it when the idle evens out. You need to drive around and your economy gauge should be on top of the O in idle with the transmission on drive. After you get it close, just do fine adjustments and that's it, worked for me as you can see in my smog test.
Oh, and i was wrong...you're running rich... anything less than 14.7 is rich and more is lean...the %CO2 means your air/fuel mixture...also, try adjusting the transmission and accelerator linkage per manual instructions. You have everything you need in that manual, thanks btw for posting it.
Make sure you have a clean air filter when doing the smog test too...
Good idea about the linkage. I will make sure its all in spec.
So gameplan: Change oil, adjust mixture, throw some ISO-HEET in, adjust linkage and pray
I'll report back in a few days fingers crossed.
here's more info on ISO-HEET
http://www.turbobuick.com/forums/smo...pass-smog.html
One guy had 140 HC and with 1/4 tank and 2 gallons denatured alcy after the test he had 25 HC WOW!
