Your 104 sounds like a diesel when starts
ie.
m103: Fuel accumulator = fixed warm start problem
m103: Fuel Injectors = Might fix misfire.
ie.
ie.
I can contribute quite a few
m103: ABS Light stuck on = OVP/OVP Fuse in most cases.
Since then I have loosened the top bolt of the tensioner shock and fabricated a small wooden washer to insulate the wobble. Now, its a year later and its back to annoying me. For some reason I have been avoiding to attempt this at all costs as it seems a bit tight in there. I hope the rad won't have to come out....anyhow maybe you will help me overcome my fears! haha I'll be following this thread for sure GEDaggett
Like you said do the shroud and fan removal. After that you need to remove the power steering pump pulley and the the pulley directly to the left of it (sorry I can't remember which one that is) after that you need to remove three bolts that are holding a mounting bracket for the tensioner and rotat it counter clockwise about 10 degrees so you can reach the bottom bot for the tension shock. Remove the bottom bolt (10mm or 11mm I can't remember which) on the tension shock and then the top (13mm). Replace with new one and reassemble. I don't believe you will actually have to remove the belt to do this although I did because I was replacing the entire tensioner. If you check the link to Ps2cho web page with the cd info there are pretty good diagrams for this. Let me know how it went. Remember on the top one you are going into aluminium so don't go crazy with the tightening. Bottom outplus 15 degrees should be fine.
