Under $150 poor mans ;) sub install! In my 87 260E
It's a much much more difficult method of installation than just making an enclosure. Trust me on this one!
http://www.decware.com/dbk10.htm
You can unplug it when you need more room in the trunk.
Read his white papers on car audio. Steve is to car audio what www.danielsternlighting is to car lighting.
Nice set up for a non boxed trunk ported
also i have seen some guys mount their subs in the same location but just build a box around the back of the sub, would this be and easier option
There's tons of information online regarding infinite baffle sub installations. I'm warning you that you will have to get into some pretty technical stuff in order to look at the specs of your sub to determine whether it will work. But if you're patient and do the research, you'll get it.
Also understand that you will have to hack the hell out of your rear deck to put 2 10's in it. Furthermore, to do it right, you have to completely seal the trunk from the cabin of the car. All of the holes in the rear deck need to be sealed. The hardest spots to seal are the trunk hinges and the head rest mechanisms, which need to be able to continue to function. You'll have to seal the rear speakers off, which means building actual speaker enclosures for them. Etc Etc. It's a huge amount of work.
Chances are, your subs will not have the specs to handle IB. So... all that said, do you still want to do this? Knowing what I know, having gone through this, the sound quality is fantastic, but the work was not worth it in the end.
Also If i were to just cut the hole in the back and install the sub after mounting an amp and everything, would it sound bad or is it something that you could live with, while not having to worry about blowing up the sub?
If you're set on the idea of cutting a hole to get the bass in, the next best thing would be to build a sealed enclosure for your sub and hang it from the back deck. You can build a fairly low profile enclosure so that you don't give up much trunk space... you'd just make it shallow and wide.
Somebody on here did that but I can't find the post.
OR... if you don't want to cut a hole but still want bass directly in the cabin, AND you're willing to do some fiberglass work, you could go this route:
https://mbworld.org/forums/e-class-w...ereo-pics.html
I still very highly recommend that you don't go the infinite baffle route. It's a huge job.
https://mbworld.org/forums/e-class-w...eaker-box.html
You can see that a 10" sub doesn't fit in the flat part of the deck, so you're going to need to replace the first aid kit cover with a custom-built cover. But it can look really good. Here's what I did for mine. You can also see the speaker enclosures I had to build since I had to seal the speaker holes for the infinite baffle sub.
