1991 E300 coolant leak
First time post and looking for some advice regarding a coolant leak. It is a slow leak that drips from the passenger side of the engine block around the middle of the block. When the engine is running the leak is faster but not too fast. When the engine warms up the leaking coolant sizzles and evaporates. I can see coolant run down to one of the freeze plugs, run down along the edge of the freeze plug, then down to the bottom of the block, and ultimately drip very slowly on to my garage floor. My commute is short, 10 miles round trip, and after few days I check the coolant level and have to refill but not very much. My vehicle has 150K miles and I recently changed the radiator.
Any ideas?
Thanks.
Any ideas?
Thanks.
EDIT: Nevermind freeze plugs are same thing. Missed it. So yes probably head gasket especially at 150k miles if it has never had a rebuild.
You can also put some UV Dye in the system to 100% find out where its coming from. You can find it at any local auto store.
I'm 10k miles into my new gasket and no problems
