Need name for whinning M103 Pulley
1990 w124 260E
Hey !!
I just got a 90' 260E W124 and I'm super happy with the car, I have owned many cars/SUVs before but non compares to the 260E W124...I am in love with it and bought it for keepsss...I have a few things to repair on it before I can fully get to appreciate it and feel it out...I started with a DIY oil change and fuel filter change which seemed to be well needed....transmission fluid and filter this week and I want to change a whinning pulley that makes noise on starting and also when driving....
I identified the noisy pulley to be the one ontop of the water pump, it's located just above the reservoir with the power steering fluid(if you know how I can change the P/S fluid I would be grateful for some advice)
I 'm not sure of the name of the pulley????....I have seen many differeent names but confused...does anybody know the correct name ????
I would like to order it this week...
Next I will attempt another DIY to change the valve stem seals, I see some white smoke intermitently when the engine idles and when i speed up suddenely and stop....
I am happy to find a W124 forum where I can correspond with fellow w124 lovers....
Cheers All!!
Cheers All!!
This is the tool I used to do the valve stem seals w/o removing the head. You'll need two people to do this though. A kid will work...just someone to remove the valve shims + seals while you hold the spring out the way.
![](http://i135.photobucket.com/albums/q143/sjkeysj/Merc/SprnigCompE.jpg)
Of course, first check if it really is the valve stem seals. Your plugs should look like this: (bare in mind mine were leaking like no other...but the color + deposits should be the same)
![](http://img.photobucket.com/albums/v229/microg00mba/dad/Plugs.jpg)
1 Post
95' AMG SeeThreeSix
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
1990 w124 260E
Need help to replace the belt tensioner on my W124 (M103)
I have read a few threads and some people have said it is a quick fixer...5 - 20 minutes, but no instructions or pictuers on how to do it....I am not so sure, it looks like I will have to remove the fan and maybe my radiator to get to the pulley properly...does anybody know how to do this... I also nee to replace my valve stem seals and would do both at the same time...thanks much..
1990 w124 260E
Thanks for the advise PS2cho, I checked my spark plugs and they looked pretty much like the pics you posted....I will take on the valve replacement job soon, I think i can do it myself, i also need to replace my tensioner pulley at the same time but still looking for some detailed instructions and pictures for both jobs...anymore help or advise is very much appreciated....thanks again...
'98 S500
Don't know a quick way to replace just the pully.
If it is the pulley, my advice is to change all of the connecting pieces. It just a matter of time before you have to do it anyway, so do it now while you have it apart.
belt tensioner assembly (includes pulley)
follow this link for an example at Autohausaz
https://www.autohausaz.com/search/pr...ber=1032000870
shock
belt if the ribs are broken/breaking
Faulty memory but I think this is what is required
Remove fan shroud
remove fan - don't need to remove radiator
remove two pulleys
remove serpentine belt
drop the ps pump
remove top tensioner shock bolt
remove tensioner/mounting bracket
reverse to reinstall
Let me know if you need more details. I have a few pictures of the process.
J
shock
Remove fan shroud
remove two pulleys
drop the ps pump
J
Here's the thread:
https://mbworld.org/forums/e-class-w...placement.html
Remember you must have a compressor able to do at least 5bar. You need 5bar to do the job.
