Blown Head Gasket allowed oil to corrupt cooling system
Ok will an investment into a dremel tool do the things you listed Wagmar?
I've already been working on that...
If you have orig. valve guide seals, replace them, they harden w/age & allow oil to leak down through the guides, then down into the combustion chamber. After my gasket replacement, I now use 1qt. per 2.5k miles, so I know everything is in pretty good shape. Fuel consumption is 21 city, 26 hwy.
I guess it depends on my engines level of wear and tear...
Ps2cho what do you think I should do as far as the dremel tool?
You can carefully use 120/180 to rid of any leftover gasket remnants on the block. You want it clean enough to eat off. I would first use gasket remover product though.
How many miles has been it been since you had them replaced in '04? I'd say any more than 60-70k miles and I'd do it for peace of mind and extend your life by another 5 years or more depending on much you drive.
Wagmar your guides are probably had some slack in them (even just a little) and that is the reason your consumption is still there. Since my rebuild I have not used a single DROP of oil. Not one. Nothing. This is how it should be, anything less means something is not functioning as it should. These engines like they burn oil, but with everything up to standard and fresh, it should not burn. It has been I believe 6k miles since my rebuild 16 months ago.
As I said, replace them if it been some miles since the last. It will cost ~$100 in parts. Just hand it to the guy who is going to skim your head as he has done it thousands of times. (Make sure you get your old ones back when you pick up. A sign of a good shop and it is a check that he actually DID the work...this applies to any sort of work).
Dremel with any of the cleaning attachments will work fine. The point I am making is that you do not want to damage via abrasive measures. One advantage to cleaning the tops is that you can check for any objects that may have had some fun in the chamber at some time and CAREFULLY sand out hotspots. I found one hotspot on mine from something.
Glad to hear it is out.
PS: Use a bungee cord like I did to hold the chain up. You don't want it falling down!! Attach it to your hood and then it is safe
Valve guides, seals, valve springs?
6x intake, 6x exhaust
1x stem seal kit
If you don't have the head gasket bought yet, I recommend this set. It had every gasket I needed including the front timing cover one.
https://www.autohausaz.com/search/pr...20Gasket%20Set
14x Cylinder head bolts if you don't have these either yet. You cannot reuse head bolts, if I have not mentioned that already.
https://www.autohausaz.com/search/pr...%20Head%20Bolt
Yeah I already got that gasket set. Im about to order a lot more stuff from there. AutohausAZ is definitely the best place to get parts.
If you want to see more salvage yards, see Car-Part.com
Its an auto recyclers' consolidated website and gives you nationwide reach. I found a very good yard here in the Dallas area from that website.
The free shipping on $50+ and no tax for me just makes it killer!
It's either going to be $40 bucks meaning the head is no good. $125 cleaned, skimmed, and tested or around $300 for a valve job.
The guy I talked to at the head shop pointed to a place on the head where something got into the gas perhaps and caused a rough place on the bottom of the head. He said it was no big deal and that whatever it was probably got blown out of the exhaust tailpipe...
Im guessing my fuel filter is in the back next to the dual fuel pump assembly?
What's the procedure for making sure my fuel system is good to go?
I recommend you purchase this book:
http://www.amazon.com/Bosch-Fuel-Inj...1119486&sr=8-1
It has every procedure for the K-Jet diagnosis and repair. It is an invaluable resource.
They will not load up each one is too big of a file. If anyone wants to seem them just PM your email and I'll send them to you...
Last edited by loclark757; Apr 12, 2010 at 08:55 PM. Reason: Pics will not load...
Where do I get the manual for my transmission? Someone told me that they have it. I forgot who it was.
Try to keep the subjects better organized on here. My mistake...
What happened to your transmission rebuild thread Ps2cho? I can't find it...
Last edited by loclark757; Apr 13, 2010 at 06:39 AM. Reason: Ps2cho's transmission thread...
A tiny sliver of plastic broke off that holds the guide rail pin but the part that came undone snapped right back together. Should I worry about this?
IM WORKING ON GETTING SOME PICS...
Should I hold off on this until I get the car put together? Im about to order a bunch of parts from Autohausaz and I want to make sure I got everything on the list...
Head Gasket Set
Air Filter
Bypass Hose
Coolant Hose to expansion tank
Head bolts
Head Washers
Distributor Cap
Distributor Cap Cover
Supressor Cover Rotor
Distributor Rotor
Oil Filter
Radiator Hose Upper
Transmission Filter
Transmission pan gasket
Im doing a tune up as well...
