Blown Head Gasket allowed oil to corrupt cooling system
Did you check the air hoses like I said? I had this problem a few weeks ago where the car would not start and I found a split hose...Made a thread over at peachparts about it.
Have you cranked, pulled the spark plugs and checked to see if they are wet?
I wasn't able to remove the fuel system shield. I didn't have time today. The fans came on but no sound at all from the fuel system.
Is that a permanent fix for the relay?
Im out of daylight for the day.
31 15 87 87H
50 TD 30 87K 87V TF
The pattern is four prongs plus another six beside it in a row
Which prong hole do I put the wire into? Jump it to where?
There's a pick and pull here in town that has a ton of 190E's and 260E's I wonder if they will work on some parts.
A local junkyard has a 1990 300E im keeping my fingers crossed on the compatibility and condition of the relay...
Here is a thread I found. I would jump it first before spending any money. You won't damage anything. You don't even know for sure if the relay is the culprit yet.
You want to connect circuit 30 to circuit 87 at the relay socket. I just checked the service manual and the relay on this thing is a 12 pin monster with all kinds of stuff going on inside it. You want to jumper pin 7 to pin 8. I always use a 15 amp fuse in a fuse holder for my jumper wire. I've got a fuse holder with spades attached to the wires to use on VW's and Volvos and such where it's a simple 4 or 5 pin relay socket.
Not sure what the pins look like on the 300E, but you should be able to spend less than $5 at Radio Shack and come up with a fuse holder, fuse and some appropriate connectors to jam in the relay socket.
When you connect pin 7 to pin 8, you should hear the fuel pump running at that point. If you do, the pump is good, get a new relay. If you don't hear the pump running when those two pins are jumpered, the pump is bad, replace that.
And obviously, if the fuse vaporizes when you put the jumper on, you probably have a short to ground somewhere (unless the pump is shorting out internally). If the fuse blows, disconnect the pump and try another fuse. If it doesn't blow until the pump is connected, it's a short in the pump. If it blows with the pump disconnected, you've got a short in the wiring.
Good luck with it. Let us know how it goes.
PS. Don't drive it with the jumper installed. The job of the fuel pump relay is to shut off the fuel pump when the engine stops running. If you get in an accident and a fuel line is broken from the crash damage, the relay will turn off the pump as soon as the engine runs out of gas and stops. If you just leave the relay jumpered, the pump will run until the battery runs out of juice. This can cause a nasty fire in the event of an accident. And the pump will keep pumping fuel to the fire as long as there's fuel and battery voltage.
This is the same car they're referring to! The guy talked about pin 87 and pin 30 and it worked. I don't want to short my system or risk anything shady. The numbers 7 and 8 are not on my fuel system relay.
Could this be an issue for the electrical system?
Just bridge the 87 and 30 and be done with it! You'll be fine. What's the worst that can happen? You fry the pump? Unlikely...
Pin 7 and 8 might be referring to the actual pins on the relay if you wanted to set up some sort of manual pump switch to override it with the relay in place. Not sure, but that would be my guess. Check the underside of the relay for any #'s that correspond.
Yeah but the battery connections work so I'll worry about it later if I have any other problems.
Im going to try the jump today and get some fuel pump relays...
Fuel is just not reaching the injectors and coming out for some reason!
So this means the fuel pump relay is bad as well. I thought the car would come on since its jumped.
There must be something loose or clogged in the fuel system. Im going to check it out and put the car on ramps tomorrow morning.
