W124 Steering Wheel Thread
Click here for a photo of the early Sportline leather wheel as seen in my 1992 500E.
Click here for a photo of the late style Sportline wheel with the "triangle" airbag.
Any leather wheel is a nice upgrade from the vinyl wheel used on the early 124's though!
You should look at my site, www.2phast.com/500e (under the interior section) which details several different wheel swaps. Currently, I am back to using a 1999 E55 wheel/airbag (sold the RAID)
Should also be noted that the regular wheels from 98-99 look the same as the 92-97 wheels, but MB changed the airbag design. So if for some reason you ended up buying a 98 wheel, you need to make sure you get a matching airbag from a 98 or 99 wheel. I explain this a bit more on my web site. When possible, always try to buy the wheel/airbag together, that way you avoid any compatibility issues.
Personal preference though, you can run with any wheel you like. I didn't really like the RAID wheel I had nor did the looks flow with the interior of the car, hence why I switched back to the E55 wheel. I won't be changing wheels again as IMO, this is the best wheel upgrade for any W124, W201, W126 etc.
Also, what is not shown in the picture is that I now am using the AMG airbag, looks exactly the same, just says AMG on it. Originally I elected to not use the AMG airbag, but since I recently added AMG wheels to the car, I swapped the bags.
Old VS New (back in 2003 when I first got the wheel)
EDIT and here's a couple of more recent shots...
RAID wheels are the only aftermarket wheel to utilize a SRS Airbag. These are popular in Europe and Aston Martin uses them on some of their vehicles. The wheel is much smaller than any OE Mercedes wheel.
Shift knob is nothing special, just a leather W203 knob, believe its from a C230. Bought the whole assembly cheap, two dollars if I remember correctly. There are nicer knobs out there (if you want to spend $50-100 on one). I have a shift shaft from a W202 in the car, so I can use any of the newer twist on knobs.
The entire headlight level control panel is part of the Brabus Tempamatic system. The Tempamatic system includes a new dash mounted temp display, outside temp sensor and oil temp sensor. The buttons allow you to switch between outside temp's (in celcius) and oil temp. Oil temp sensor is mounted in the drain plug.
This item is not currently on my website, I did update it but must not of uploaded the changes to my ISP, so need to re-do it at some point. I will post a few pictures in this thread though.
