Updated Sway bar, Bilstein Sports. Comparisons
Sportline sway bar (snagged it off a 300TE) is thicker in the middle (26.5mm vs 27.5mm), and definitely thicker on the outside's (18mm vs 22mm). A nice cheap upgrade...
The new sway bar bushings to fit in the middle were a little tricky. I left them in boiling hot water for about 10minutes to soften them, then gently used a rubber mallet tapping each side until it got over the curve. You do not want to do this dry otherwise you could risk stretching the rubber and not getting a tight fit.
Shorter shaft on the sports:
The car also seems more firm on braking too..less nose dive. I'm very happy with my decision to get the sports. If anybody wants a set of pretty much new Front Bilstein Comforts shoot me a PM! They have probably no more than 2000mi on them. I bought them new and put them on in the beginning of October. My daily commutes are 20mi...so I've put pretty much no miles on em.
i thought the limmo bar/cabrio bar was bigger than the te bar?
confused
http://www.w124performance.com/image...4_swaybars.pdf
I will drive the car a little harder today on my commutes to get a better feel as to the stiffness. From the short drive last night, it still feels very comfortable.
Also, ps2cho, wouldn't you need to do the rear swaybar as well or it'll understeer too much with just a thicker front bar?
Well the rear is a little more work to get at...Possibly in the future...Maybe I'll update to the rear 400E brakes and while doing it I'll get the rear bar. I don't corner hard that often so I'm not worried right now.
How difficult compared to the front swaybar is doing the rear? Maybe I'll find a sportline rear swaybar and new bushings? I am doubtful on the "size" of the swaybar being the issue because the wagon uses the sportline sway bar at the front, but the 15mm regular rear bar. Maybe it is just worn bushings like the front had?
The car does not track or wonder on the freeway so I don't see rear control arms being problematic. My wagon has bad rear arms so I know the feeling of them. Anything else I should check back there?
It kinda feels like it is gliding in the rear when taking corners hard if that makes sense?
I think it is because the rear of the body can flex more than the front can and because of that, you can lift your wheels a bit more if you torsion the chassis by cornering/declerating.
I still can't get my mechanic here to tackle the rear install, but now that I have my subframe bushing kit he said that he would do it (time permitting). His concern is that, having to drop the subframe to remove the old bar and insert the new bar, that the bolt that goes into the bushing would be seized, etc and that the subframe bushings would get ruined during the install.
I'd suggest you get the kit and keep it on hand if you're going to do the rear just in case. I'll let you know what it came out to $$ wise and what he said if I can get to it before you do.
http://www.w124performance.com/docs/...ar_install.pdf
I think the main bushing that was worn was the rear trailing arm bushings, because they came from another car when I did a brake upgrade.
