Hi All!!! I would like to introduce myself and get some advice while I am at it! =)
I am new to this forum but not forums in general. Personally I do not own the MB rather it is my parents car that I would like to become more knowledgeable about and work on.
The car is a 1991 MB E300 3.0 with ~170K. The outside and inside of the car are a 10/10 but there seems to be a problem with it starting, the RPM no longer working and transmission.
problem a) Transmission
This is probably the most serious of all the problem. The problem is that the tranny shifts very hard and aggressively through gears 1-3...it does seem to get a little bit better once the car warms up but overall a very bad shifting tranny indeed.
What could be the problem?
I suspect that the tranny is low in fluid...or the Flex Disk is rotten....or a bad tranny?
problem b) The RPM tach
basically the RPM no longer works on the dash. The car is not affected in any means but it does bother me that it does not work.
how can I fix it?
problem c) Hard starts
This is basically a long crank time and finally when it does start it has a sloppy start for the first 3-5 seconds and then smooths out. It is a problem b/c sometimes my mom cranks it too long because she gets frustrated with it.
I was going to run some injector cleaner as to eliminate that possibility. What could be the problem? is it a spark plug issue?
Overall the car runs a straight line and it is like riding on cloud 9 on the freeway. The steering is smooth and everything else seems to be perfect...
Thank you for all the help ladies and gents...
p.s. I did a search but my questions were not answered for my particular car
a) When was the last time the fluid + filter was changed?
b) You will need to pull the cluster out and replace that "part". I guess you could fix it yourself if you are handy, but I have never done it. You cannot buy that section separately so maybe find someone who is selling a whole cluster for cheap or go to a local junkyard and pull one. Easy swap.
c) Check spark plug condition and go from there. Last known tuneup?
I have a feeling they might have poured the old fluid back in...so I may just change it again just to be sure...
i) what type of fluid do I need?
ii) What brand?
iii) how many quarts of fluid?
iv) I have done it on BMW but never on a Merc...is it similar? I have the bently book but is there a write up of pdf one for the merc?
b) dang I didn't know the whole thing had to be changed...hmmm I will look on eBay and check out some junk yards
c) I think the last tune up was performed around 120K or so but I think when I get some time on my hands I will change out all the filters again (fuel, air) , spark plugs, and run an injector cleaner...
I forgot to ask..is it normal for these engines to burn oil? I have changed from Dino to 10-40W high Mileage Mobile 1 hopping to get better results...
If you are in doubt of the fluid replace it. Any dex III will work. I like either Redline Synthetic (since yours was fixed for leaks) or Valvoline Maxlife Dex III
Do a complete tune up -- Spark plugs/Ignition wires/rotor/cap/fuel filter/air filter and go from there. Shouldn't cost you much.
I have extra DEX III from my BMW tranny oil change so I will most likely stick with that...is there a write up on the procedure on the site? I have read some things about having to tilt something with a 27mm socket to get the excess oil???? what is that? where is it?
as far as the tune up parts go...I did a rough shop around online and it seems to be about $100 bucks...not bad...
It will be more along the lines of $300. Stick with Bosch.
The 27mm socket refers to turning the crankshaft so you can gain access to the drain plug on the torque converter. ~3quarts in the pan, ~3quarts in the torque convertor. You must drain both or it is pointless
I have a short DIY on my sticky for tranny fluid IIRC.
-Mike
-Mike
thanks
0030945404
Mann (OES)
Air Filter
Q1030002
Mercedes (OE)
Antifreeze/Coolant; Antifreeze; 1 Gallon SUPERBLUE
ATE
Brake Fluid; Super Blue Racing Brake Fluid; 1 Liter
7978
Bosch
Spark Plug; SuperPlus Heavy-Duty; Yttrium Electrode
1262770295
Mann (OES)
Transmission Filter 007603-010100
Fischer & Plath
Transmission Gasket/Bushing/O-Ring; Aluminum Seal Ring at A/T Converter Drain Plug;; 10mm Aluminum Seal Washer; 10x14x1mm
007603-010112
Fischer & Plath
Transmission Gasket/Bushing/O-Ring; Drain Plug Seal; 10mm Copper Seal Washer; 10x15x1mm
1262711180
Woco
Transmission Pan Gasket
000000-000648
Mercedes (OE)
Transmission Pan Gasket; Transmission Pan/Torque Converter Drain Plug;; 10mm Drain Plug; 10x1x8mm
Go with Bosch H9DC (NOT HR9DC) or equivalent.
I bet that ATE brake fluid is expensive. Get some nice DOT3/4 at a local walmart for cheap. It will work. Coolant though -- stick with MB or Zerex G05 (same product).
I searched google but did not find anyone who sells H9DC so I went to the Bosch site and they recommended the H9DC0...same thing?
http://www.boschautoparts.com/Vehicl...CAT=SparkPlugs
as far as the ATE brake fluid goes...it is only 15 bucks but makes a world of difference...I first used it on my race bike and was blown away by the performance then put it in the bimmer and loved it so I have a feeling it should be worth a try in the merc
http://www.autohausaz.com/search/pro...@Brake%20Fluid
As far as the coolant goes I think I might just go with the Z-05 being that I have 2 gallons sitting in the garage!
When I went to look for the fuel filter I noticed that there were in-tank and out-tank ones...do you which one I would need?
http://www.autohausaz.com/search/pro...@Fuel%20Filter
