Still looking for Benz to buy.
Old Jan 13, 2011 | 04:00 AM
zh000's Avatar
1994 Mercedes-Benz E320
Exclamation Still looking for Benz to buy.
Hey guys, everyone I have been posting about w124 earlier, and I am trying to find a good deal still Was wondering if that benz that is in this link i a good deal to buy?
It is 1994 MB E320 with Mileage of 156k, and he wants 2700 hundred for it. So, what do you think?
Thank you all for you responses.
Last edited by zh000; Jan 13, 2011 at 04:01 AM. Reason: forgot the link: http://portland.craigslist.org/mlt/ctd/2156936672.html
Old Jan 13, 2011 | 04:02 AM
zh000's Avatar
Old Jan 13, 2011 | 12:58 PM
190E 16V's Avatar
1987 560SL
Looks nice, but you need all the mechanical information.
Ask the seller about
Rust
Head gasket
Transmission - reverse will go first
Timing chain last replaced when?
A/C Evaporator - leaking? Not working? Expensive repair
Driveline FLEX DISCS
accidents - no badge on trunk, could have been repainted from repair
Then test drive to make sure suspension is tight
Clear title? Not salvage?
Old Jan 13, 2011 | 01:01 PM
Speedriven1's Avatar
Speedriven
Rust
Head gasket
^ this.
Don't buy anything without a proper PPI.
Old Jan 13, 2011 | 03:04 PM
semis1's Avatar
'91 C124 300CE,'06 ML 500 W164, '00 BMW MCOUPE, '65 COBRA REPL.
It looks good, the miles are right at normal BUT it has a branded title. This probably means salvaged or reconstructed depending on state. The front left (driver's side) gap on the hood and fender, as well as headlight and side marker look a bit off.
The rear badge is not a sign of anything. It is held on with sticky tape and can be removed easy. I removed mine because it was gold (blah).
The branded title will not affect resale value. It already is low. Well maybe $500....
If the seller has documentation or can explain what the accident is, take a look at it.
All panels, doors, fenders, hood, trunk lid etc. have a sticker with the original VIN #.
Look for them and you will see which parts have been changed.
Service records are nice to have, at least have it inspected.
Good luck on your quest.
Old Jan 13, 2011 | 03:36 PM
zh000's Avatar
Hey Thank you! I have talked to him, and he said that it was rear ended, and it was a small damage, so all he got to do is to change the light or something... I just want to buy w124 that won't be crushing into pieces on my eyes. Looking for about 5 years to ride on it....minimum)) But he says everything working.
Old Jan 13, 2011 | 03:51 PM
semis1's Avatar
Well, at the price offered, you can't go really wrong as long as it is working properly.
These cars will last, but need maintenance and if not, things are not cheap.
Go take a look at it. Make sure that the transmission engages quickly. Specifically reverse. This is a problem with these cars.
Remove the coolant cap and see if there is any oil in it. If yes, run. Head gasket.
With the car running and warmed up, remove the transmission dip stick. The level should be at Max and the fluid nice an clean.
Take your time, spend time with the car before buying, check everything.
Old Jan 13, 2011 | 04:02 PM
zh000's Avatar
Smile
Thank you very much!
