FS: 1995 E420, 150k, ASR, 2.82 Rear, Central NJ $3750
150,xxx miles
Smoke Silver Metallic and Mushroom Interior
VIN: WDBEA34E2SC175943
Clean NJ title
The Good: (things replaced in my four years of ownership)
- ETA rebuilt
- Distributor caps and rotors
- Upper and lower wire harnesses
- E500 front sway bar
- Lower control arms
- 2.82 differential with original cluster including modified and accurate gauges
- 23 gallon (90L) gas tank installed
- Various oil leaks fixed
- Serpentine belt
- Shifter bushing
- New resonator (center muffler)
- Oil pressure sending unit replaced
- Rear Bilstein shocks (not HD)
- New Stereo: Alpine CDE 123 Deck with CD, XM Satellite Radio (module installed), Front and Rear USB, full iPod and iPhone control, front aux, Bluetooth capable (module not installed) and 6 channel preamp output; Rainbow front and rear drop in replacement coaxial speakers; Soundstream Granite 180 watt 6 channel amplifier; and JL Audio 10” subwoofer in box in trunk
- OEM Ashtray Delete/Storage Tray installed (have OEM ashtray as well)
- One set of AMG Mono IIs. All 17 x 7.5 ET35. All are straight with lugs, center caps, in good condition, and 225/45/17 Michelin Pilot Sports that have minimum tread left
- One set of OEM 8 hole rims from a W210. All 16 x 7.5 ET40 with lugs, center caps, in good condition, and 215/55/16 Nokian Nordman snow tires that are in their second season. There is small vibration on the car at highway speeds so I think one (or at least one) is bent
- S600 knockoff grille (have OEM one as well)
- Two master and one valet key\
- Rear rotors and pads at minimum spec
- Could use a HVAC mono valve. Heat works fine but A/C blows hot and cold. (You could clamp the heat vacuum line in summer like I did last summer)
- Outside temp gauge in instrument cluster does not work
- Timing chain cover is has minor leak
- Driver seat heater does not work
- Front spoiler has crack on bottom
- Radio antenna will not retract
- Original radio, rear speakers, and amplifiers
- One pair of used Bilstein HD struts and assorted new coil spring shim perches
- Half of a AMG W124 front fender spacer kit (only two bushings and screws)
- Complete rear deck shelf
- Extra trunk floor mat
