89 260E idle surge
Old May 8, 2004 | 11:00 PM
Stunnd's Avatar
1989 260E
89 260E idle surge
I bought a 1989 260E recently that has 108,000 miles on it. I thought it was a good deal, but it's turning into a money pit. It currently has a problem where the idle just surges randomly on its own. It is an intermittent problem and the 3 mechanics I've used haven't found the problem yet. Some new parts include a throttle body, fuel pump, fuel lines, fuel distributor, fuel filter, starter, and overload relay. The MB dealership also claims it needs a valve job. Has anyone ever experienced this surging idle before? This is my first Benz and I'm quite discouraged.
Old May 9, 2004 | 02:31 AM
Edgar's Avatar
could possibly be due to a fault in the oxygen/ lambda sensor that's causing the surge when idle. Had the same problem, which was rectified when the sensor was replaced!
Old May 9, 2004 | 07:41 AM
Stunnd's Avatar
1989 260E
Thanks for the tip. I'll give it a try.
Old May 10, 2004 | 07:21 AM
blackbenzz's Avatar
haters crazy
I had the same problem with my 260E and replaced the same parts you did and it ended up being O2 sensor.
Old May 24, 2004 | 08:30 PM
Stunnd's Avatar
1989 260E
Were you simultaneously having an issue with the idle surging sometimes and then stalling at other times? I'm hoping the oxygen sensor fixes both of these issues that I'm having. I expect to have it replaced this week.
Old May 25, 2004 | 09:48 AM
Stunnd's Avatar
1989 260E
One mechanic is telling me that unless the Check Engine light is on, then it can't be the o2 sensor. It's about a US$300 job to install the sensor, so I'm just going to have it replaced and see what happens. Was your Check Engine light on while you were having the same problem?
Old May 25, 2004 | 01:02 PM
blackbenzz's Avatar
haters crazy
My check engine light was not on (bulb may be bad, i dunno?) and I had a slight stalling problem but the car would never shut off, it would just studder. Now my little bro hit a speed bump going too fast and broke the exhaust in half Now I gotta fix that
Old May 26, 2004 | 10:21 PM
Stunnd's Avatar
1989 260E
Had it at the dealership today and it turns out that it's not the 02 sensor but the stinkin' ECU. Looks like it's time to cash in another mutual fund!
Old Jun 8, 2004 | 09:25 PM
spsinha's Avatar
1994 E320 Coupe, 1979 500SLC, 2005 E55 - Sold
Check Ebay, I always see used ECU's for sale on there.
