HFM and manual transmission coding
Here are a few reasons why this is important,
1. idle control, the car things it's always on park. Unless you know for sure because you've been deep in the ECU maps, I don't know having the ecu think it's always on parkesses with timing and emission controls. The manual trans cars have a clutch switch input, connector 1 pin 22 which should directly effect idle speed and also kill the cruise control when the clutch is pressed.
2. The transmission overload switch. The 722.3 had this switch and it retards timing when the transmission would be under heavy load just before or during a shift to help as a torque management solution. It only activates sometimes and there is some kind of logic built into the ecu to detect if it's working. I'm the HFM manual it even states of there is a high speed missfire, check this switch. So it effects timing and it cannotnkisy be jumped to bypass it, I've been down this road. Setting the ECU to know it's a manual transmission will ignore this Input.
I have a USA car with a cat, cruise, no asr and a 5 speed. There is no coding info I can find for the USA car. I found this combo for a euro eur and it would not take the coding number, HGMscan would report coding failed. Also the euro cars I think all had a CO pot to adjust fuel mixture, which no USA car has. There was also only one other HFM car that know of that was manual and that was a euro c280.
So what can I do here? Not having this set right is effecting performance.
Second, In the HFM manual it tells you exactly what the overload protection switch does, and how it effects drivability when failed. And when disconnected or bypassed it is assumed failed because a fault sets in the ECU. It has to see that switch open and close when your driving. I don't know how the fault logic is setup, but it is there and it pulls timing.
There is nothing fancy about the wiring for the 3.6. it's the same engine as what was in there before, an M104. The only thing that was done was the ECU flash for fuel and timing maps, everything else about operation of the engine is exactly the same and any m104.
The shift delay solonoid is the least of the issues, because all you do is remove the vacuum line, cap it and leave the solenoid plugged in.
If you research that overload protection switch you'll find out exactly what it does. It's a huge misnomer that you can just unplug it or try and bypass it and not effect top end drivability. It's just the the SLS shocks. Everyone seems to think the rear accumulators control ride quality. But in reality the SLS shocks are regular shocks that do wear out...difference is they have the ability to be raised and lowered with hydraulic pressure. The accumulator is there to be a resavoiur for the non compressible fluid when you go over bumps, the fluid it has to have a place to go. But as far as ride quality and control, the shocks are shocks. Unless the accumulator fails. Then you get a hard harsh ride. If not attended to soon enough, that hard ride works the valving in the shocks tod and you will get a floaty ride like an old American car. This is exactly how my wagon was when I bought it. New SLS shocks made it ride hard and stiff, it was then obvious the accumulators failed, and they were ignored till the shocks wore out.
For now I connected the overload switch to the clutch switch. So the ECU is seeing it open and close. When my foot it off the clutch, that would be the normal state of the switch. I'll see how it goes after a few weeks and I'll know if that will be enough to keep the ECU happy. But so far, I've felt no issues at high rpm high load like I had before.
Unaware of how the ECU knows if in park or not except for the NSS which I believe only interrupts the starter circuit. No other connections. Is it an engine load/unload condition? If not in park or neutral it's closed. Jumpering the proper terminals should make no difference.
If the HFM control unit does not receive a shift signal
from the automatic transmission when the car is
being driven, whether as a result of a fault at the
transmission overload protection switch (S65), brake
B1, or at the wiring, the HFM control unit switches
into the emergency running mode. The
transmission overload protection continues
operating only to a restricted extent in the
If no shift signal is sent by the automatic
transmission, the HFM control unit recognizes the
start of a gearshift as a result of a change in engine
speed within a defined level.
When the transmission overload protection is
operating in the emergency running mode, this may
be noticable as a result of the temporary retardation
of ignition timing at high speed.
M
In dealing with the complaint "Misfiring at high
speed", it is then necessary to check the
transmission overload protection switch (S65) and
also the wiring.
A transmission overload protection is integrated in
the HFM control unit in order to protect the shift
elements of the automatic transmission from
excessive thermal stresses during load shifts at
higher revs.
The HFM control unit processes the following
information for this purpose:
Signal from transmission overload protection
switch (S65)
Engine speed
Air mass
As a result of the transmission overload protection
function the ignition timing is retarded to 5° CA
before TDC (reduced engine torque) for about 400
ms during
1-2 and 2-3 upshifts.
As this retardation of the ignition timing also
improves the gearshift smoothness during the
shifting phase, this measure is also used for 3-2 full
throttle downshifts.
Here is your selector lever position Info
k) Selector lever position (AG only)
The starter lockout switch (S16/3) is used for
recognizing selector lever positions P/N and also 2/3
for the HFM control unit.
The selector lever position is required in the HFM
control unit for the following functions:
Fuel injection
- Post-start enrichment
Catalytic converter heating
Transmission shiftpoint retard
Camshaft adjustment
Governing maximum engine speed
M
also the wiring.
higher revs.
switch (S65)
Engine speed
Air mass
ms during
Fuel injection
Camshaft adjustment
The overload protection switch is a pressure switch that's activated by a valve that it actuated by the b1 band mechanically. So under a full throttle 1-2 shift or other conditions when the b1 bad is loaded right the valve is actuated and then the overload switch. This retards timing 5 deg for 400ms. It's torque management. I'm not sure how the ECU logic is setup to determine if it's working other than wanting to see it open and closing, maybe there is a resistor value in there too so it never sits open or closed. I don't know how far the logic goes, if it looks for switch activation above certain throttle positions and what not. I did hook it to the clutch switch so the ecu would see it open and closing. Closed would be clutch pressed and switch activated, so if it retards timing it won't matter really. It seems to run better at high speeds, but I need to look at the data to see what's going on and see if it's set a code. Right now I have to deal with a driveshaft vibration issue lol.
Last edited by Floobydust; Jan 23, 2020 at 07:07 AM. Reason: got the grounding state wrong
I have installed the system, but wondering if I should put the pressure switch on the clutch or if that still causes the ECU to fault in certain conditions?.
The selection for Park/Neutral-Drive probably needs to be automated on a short timer - ie 1-2 seconds after start it goes into Drive.
None of the manual coding options work on the C36 ECU, tried the early and later coding too.
People suggest using the C280 manual ECU and retune, but its not an easy option for me down here.
Mark
