w124 Petrol Engine Replacement from other Models
The engine is a 2.0L 136hp petrol (m111.940). It seems to be quite hard to find a w124 donor. I wonder if other models can be donors?
I don't want to increase displacement or horse power (so I can legally drive the car in Bulgaria).
There are w210,w208 and w202 with 136hp 2.0L petrol engines. Is it possible to use one of those and what hoops should I jump trough?
Thank you in advance!
Your vehicle uses PMS brain, other vehicles you mentioned have HFM brain. For this reason, the engine electrical wiring, the brain, and the electrical wiring on the vehicle must be changed along with the engine. also your car has fan thermal, others have electric cooling fan. The electrical installation must be rearranged accordingly. In other words, the job does not end with just the engine, many changes are required.
After some more digging (and talking to someone who has exp. with that operation) it turns out I can use only the block and pistons from a w202 136hp engine for example.
I keep the cylinder head and crank shaft from the w124 - this will eliminate the vanos that later engines of the m111 family have.
Still if anyone has more tips and advice - please share
Cheers!
HFM= Hot Film Management
Simply the differences and the nomenclature that way if I'm not mistaken. Pressure expression is included because it regulates the injection system by reading the intake manifold pressure in the engine.
