Transmission Fluid in 430
Old Nov 15, 2005 | 07:17 PM
bogene2020's Avatar
Angry Transmission Fluid in 430
I have a 2000 430. Do the Transmission fluids in those cars need to be changed . I remember someone telling that the trasmission is sealed and does not have to be changed . I am a little confused . Can anyone elaborate for me .. Thanks
Old Nov 17, 2005 | 08:52 PM
adv074's Avatar
2001 E320 Sport
Yes it is a "sealed" transmission and it's supposed to never need servicing since it's synthetic, but don't believe that lifetime BS. You're actually supposed to have the transmission fluid replaced on it every 30k? (somebody correct me if I'm wrong). I had my tranny fluid replaced a month ago. A tech I talked to told me he's seen a few trannies fail roughly around 80k or so because the fluid was never replaced. Not trying to scare you or anything but depending on your miles you should have it replaced. Dealer wanted about $300 for the job, that was Park Avenue Motors (part of Smythe European)
Old Nov 17, 2005 | 09:07 PM
StapleGun's Avatar
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
GET IT DONE!!! Do a flush and fill at least. Go to a transmission/oil service location and ensure they have a Wynn's trans service machine. I replaced the fluid on my C43 at about 74K to preclude any problems. This is a problem IF you don't do it!!! I replaced with Mobil One synthetic ATF...which meets or exceeds MB's fluids. This has been talked about extensively so feel free to review my posts, or research others for your 411.
Old Nov 18, 2005 | 09:06 AM
Ala-benz's Avatar
'00 E430, '83 Porsche 928S
If you listen to anyone that tells you that a "sealed" mercedes transmission does not need service, and they are wrong, the outcome is a few thousand bucks down the tubes.
If you have listen to those of us who recommend service, and we are wrong, then you are out $300. If you do it yourself, you have to buy a dipstick and the fluid and will spend around $130.
I am willing to invest the $130-$300 to avoid the $2500-4000 replacement bill. On my old '97 E420 I used to own, I replaced the fluid at around 90K. The transmission performed better and the old fluid was very dark. I am going to replace my fluid on my current '00 E430 with 80K within the next couple of months. It is cheap insurance.
Old Nov 18, 2005 | 12:47 PM
bogene2020's Avatar
Thanks for all the advice . I will have my trans fluid changed ..
Old Nov 18, 2005 | 01:18 PM
StapleGun's Avatar
Just for your info...I would do a flush and fill and get the entire fluid replaced. You can purchase the 'dipstick', filter, and sealed cap to do the job, you however...will not replace the entire amount of fluid in the torque converter.
Old Dec 14, 2005 | 08:39 AM
kchristos's Avatar
Don't have a Mercedes right now...
Do you need to have a special equipment such as:"Wynn's trans service machine" to change the transmission fluid? I am going to change mine by the end of this week with my mechanic. I don't hink he has any special machine for it, he told me you just empty open the panel from under, chnge the filter seal it and fill up with the new fluid. Is this true?
Old Dec 14, 2005 | 11:38 AM
E55Cent's Avatar
AMG 55, 335i, Mini Cooper S
CHANGE IT! My stock E55 tranny blew at 65k and cost $5000 and the car was gone for two weeks. Now I change the fluild every 20k. It is well worth the $200 to be safe than sorry. BMW have the same problem as MB's with the dealers saying "lifetime fluid" no such thing and the phrase lifetime is 100k not our lifetime.
Mario
Old Dec 15, 2005 | 01:59 PM
slk55lvr's Avatar
Well you all convinced me! I'm getting mine done during the next service visit...thanks for the advice
Old Dec 16, 2005 | 01:46 AM
tomscia's Avatar
1998 E320 Sedan
I changed the transmission fluid in my 1998 E320 with genuine MBZ transmission fluid. In addition to draining the pan, I hand cranked the engine to line up the torque converter drain plug and was then able to drain it too. Thanks, Tom
Old Dec 16, 2005 | 05:49 PM
king_j's Avatar
if its a "sealed unit" how do you drain it?
remove the pan?
do you guys power flush the fluid out, or let is drain?
can you refill the trans. by the capped dip stick?
Old Dec 16, 2005 | 06:17 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
remove the pan?
There is a drain on the Trans Pan and a drain on the Torque Converter..Up to 2000 Model year
To refill the trans fill through the fill tube...
You WILL need a Workshop tool (DIPSTICK) to check the fluid level when warm
and a Tamper proof cap for the dip stick/fill tube
Old Dec 17, 2005 | 03:38 PM
Ala-benz's Avatar
remove the pan?
Thats the irony with these transmissions. they are "sealed" but have a drain plug on the trans and the torque converter. No need to drop the pan unless you are changing the filter too.
Old Dec 19, 2005 | 09:32 PM
king_j's Avatar
i have a 97 E320.
i was told by the MB dealer that there is not a drain plug, and the pan must be dropped in order to change the fluid.
Old Dec 19, 2005 | 10:15 PM
E55Cent's Avatar
i have a 97 E320.
Seems like the 320 has the same issues as the V8's. You should change your fluid also, but only with OEM MB fluid. It differs from car to car and year to year.
Old Nov 6, 2007 | 02:21 PM
Pablissimo's Avatar
I would suggest that you drop the pan, whether or not there is a drain plug. A new filter is only about $10-$15 and it should always be replaced when you replace the fluid. More reasons: there is still over a quart of fluid left in the pan after using the drain plug, and dropping the pan allows you to inspect for any metal debris and clean the magnet.
Old Nov 6, 2007 | 02:24 PM
ohlord's Avatar
I would suggest
newbies read the dates of the post they are replying to,lest some think them really nooby
