Check Lamp light is on
Old Jan 9, 2006 | 04:06 PM
E320Star's Avatar
2000 E320 Sedan
Exclamation Check Lamp light is on
My lamp chekc light comes on from time TO TIME W/O ANY REASON. I checkec the headlight's/fog lights, rear light, signals ......u nam eit i checked it. No lamp needs replacement. What gives !!!
Old Jan 10, 2006 | 12:47 AM
Mr. B's Avatar
'97 E320
have you physically checked the bulb connections..??
one may be loose and still working when you look at it but randomly throwing a error… just guessing now...
sounds kind of strange
~ Mr. B ~
Old Jan 10, 2006 | 11:43 AM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Take a look at the Tail light Bulb Holders...They melt and will cause a loose contact....seen Several do this!
Old Jan 11, 2006 | 03:58 PM
JimPurdy's Avatar
11 ML350W2 / 17 GLC300
Yes, the tail light bulb holder can cause a problem. I have been having intermitant "Bullb Failure" messages and was not able to see which bulb was causing the message. I finally found that the bulb holder was not making good contact with the tail light assembly and had arced and pitted the tail light. I have cleaned the contact area and bent the bulb holder contacts to make better contact. If this problem comes back, I will have to replace the tail light assembly.
Old Jan 12, 2006 | 11:55 AM
sts15's Avatar
2015 E350 4matic Sport and 2011 C300 4matic sport
lamp
I have had the same problem since buying my car. It is very periodic and I have not had it occur for two weeks now. Often it would just occur for one short drive then the next time I started the car and turned the lights on it would be gone...Knock on wood...I think it is a gremlin who comes out just to scare the **** out of me. I also went through high water and all the brake like malfuction messages came on, but the next time I started the car it was fine...
Old Jan 12, 2006 | 12:31 PM
4XFORE's Avatar
1998 E320 / 1992 LandCruiser / Project Car E30, 91, 318I
same thing happened to mine. i did the same thing. if this problem comes back then it will be a good reason for me to get the smoke or clear tail light assembly
Old Jan 13, 2006 | 09:54 AM
E320Star's Avatar
2000 E320 Sedan
I re-checked the connectors, I switched them with the left right side. Then I noticed one balb is dark and about to go out but not yet out. I replaced it. It has been 3 days now without any problems, Knwo on wood too.
Old Jan 13, 2006 | 11:55 AM
JimPurdy's Avatar
E320Star,
Look carefully at the connectors on the bulb holder. If there is any evidence of arcing, that is what seems to cause the bulb failure.
Jim
Old Jan 17, 2006 | 10:29 AM
E320Star's Avatar
2000 E320 Sedan
Thumbs up Thank you
I sure will if it hasppens again. almost a week now. No issue. Thanks to all.
Old Jan 17, 2006 | 11:58 AM
ruffrob's Avatar
2010 Charcoal Grey E350 Coupe
I got my fingers crossed for ya,I had the same problems over and over. Changed bulbs and saw it was a faulty fuse,but one more time,JUST ONE MORE TIME,and I'll change my tail lights to the LEDs which I have already...
Old Jan 17, 2006 | 12:18 PM
MPE430's Avatar
2016 E63S AMG, 2012 ML350
check the license plate lights-they are hard to detect when out.
Old Jan 18, 2006 | 10:21 AM
E320Star's Avatar
2000 E320 Sedan
Lic plate is fine. No lamps are out. It has been 8 days no issue.
Old Jan 18, 2006 | 10:54 AM
MB_E430's Avatar
2007 C230 Sport
I get this a lot it comes on when it feels like it. Just check, clean and reseat all the connections. It's very annoying. Try to check all the lights as soon as you get the error message it may be the brake lights that's where I get this problem.
Good Luck and keep pushing the "R" button!
Old Jan 18, 2006 | 04:58 PM
E320Star's Avatar
2000 E320 Sedan
I did replace the brake switch on Monday which was casuing my BAS/ESP light to come on. I have a feeling it may have fixed this issue too !! i forgot to ask my mechanic. Oh well !!
